Aluminum Button D Shaft 40mm Ø6mm Black
This sturdy black aluminum button has a diameter of 40mm. It can be easily fixed on the flat axis of a potentiometer or attenuator with a hexagon screw and will contribute to give your camera a sober and modern aesthetic.
Reference : 15050
6,90 €tax incl.
5,75 € tax excl.
Aluminum Button
D Shaft, 40mm, Ø6mm black
Bouton Aluminium axe méplat 40mm Ø6mm noir
Clamping screw not included. Available here : Hollow Head Screw Steel BTR M3x5mm (x10).
Product typeButton
MaterialAluminum
Shaft typeD Shaft
Shaft diameterØ6mm
Button diameterØ40mm
Button height15.5mm
Diameter (mm)40.0
ShaftSmooth
ShaftFlat
Internal widthN/A
Internal depthN/A
Internal heightN/A
Height16.0
2 reviews
comment il se fixe ?
joli bouton alu noir mais s'il dispose bien d'un perçage de fixation fileté il n'y avait pas de vis sans tète fournie...
et pour trouver une petite vis de cette dimension (3.5mm?) bonjour...
inutilisable
Bonjour,
Il se trouve en accessoire de cette fiche, des petites vis parfaitement adaptées à ce bouton.
This review has been posted for Aluminum Button D Shaft 40mm Ø6mm Black
my order
The order was received by me very promptly and arrived in good condition. Very good quality and exactly as described. I had a small problem which was caused by me not reading the description properly but this was dealt with very quickly by the sellers.
This sturdy black aluminum button has a diameter of 40mm. It can be easily fixed on the flat axis of a potentiometer or attenuator with a hexagon...
