Button Cranked Axis 30x23x15mm Ø6mm Black with LED Positioning
Knob 20x13mm Black Notched Shaft Ø6mm
This black 30mm diameter knob at its base, 23mm for its handle and 15mm deep has a 6mm diameter notched pin. Moreover, it will allow you to integrate an LED to make appear a luminous halo once installed and connected to your system (LED not supplied).
2.0 / 5
Reference : 12995
1,50 €tax incl.
1,25 € tax excl.
Knob 30 x 23 x 15mm
Black, notched shaft, ⌀6mm
Bouton 30x23x13mm 6mm de diamiètre
Dimensions30 x 23 x 15mm
Shaft typeNotched
MaterialPlastic
LED SlotLight Circle (LED sold separately)
Diameter (mm)23.0
Diameter (mm)30.0
ShaftNotched
Internal widthN/A
Internal depthN/A
Internal heightN/A
Height15.0
Pas de repère
Le grand repère blanc sur la tranche que l'on aperçoit sur la photo n'est pas un repère mais un reflet. Le bouton est donc tout noir sans repère visuel évident. Il y'a bien une toute petite encoche sur le bord mais qui est quasi invisible en vrai.
La fabrication en plastique est, de plus, très légère.
This review has been posted for Button Cranked Axis 30x23x15mm Ø6mm Black with LED Positioning
This black 30mm diameter knob at its base, 23mm for its handle and 15mm deep has a 6mm diameter notched pin. Moreover, it will allow you to...
