Linear Power Supply circuit board 4 35mm Snap in gold plated
This dedicated linear power supply circuit is ideal for designing stereo DIY amplifiers. It allows you to integrate 4 35 mm Snap-In capacitors of your choice (10 mm pin-capacitor spacing). The package contains the PCB, 2 diode bridges RBV5006 and 4 screw terminals.
Reference : 11519
8,90 €tax incl.
7,42 € tax excl.
Power Supply Module
Linear, 4 Snap in 35mm slots, Gold plated
Module Circuit d'Alimentationm
It is of course all possible to use other rectifier bridges with SIL box or other terminal blocks.
Product typePower supply bard
Available slots4x snap-in Ø 35mm capacitor (not included)
2x bridge rectifier
4x screw terminal block
PCB tracksWide tracks, Gold plated
Dimensions124 x 75 x 2.1mm
Fixation holes spacing115 x 67mm
Capacitors pins spacing10mm
Weight40g
Package1x Power supply PCB
2x Rectifier Diode RBV5006 (SIL type)
4x Screw terminal blocks
InputScrew terminals
OutputScrew terminals
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyLinear
Good quality.
Used in DAC power supply unit.
This review has been posted for Linear Power Supply circuit board 4 35mm Snap in gold plated
This dedicated linear power supply circuit is ideal for designing stereo DIY amplifiers. It allows you to integrate 4 35 mm Snap-In capacitors of...
