Balanced Regulated Phantom Power Supply Module 48V 5V +15/0/-15V
This regulated phantom power module is ideal for powering a microphone at 48V DC. The module has the particularity of also providing additional outputs at 5V and 2x15V. The module also provides additional outputs in 5V and 2x15V.
Reference : 14304
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 18-02-2025.
Power supply module
Module Alimentation Fantôme Régulée 48V + 5V + 2x15V
This regulated phantom power supply module is ideal for supplying 48 V DC power to a microphone. The module also provides additional 5V and -15/0/+15V outputs. This high-performance module is regulated by LM317, L78 and LM337T voltage regulators, providing your equipment with a clean, stable power supply. A switch makes it easy to switch the module on and off, and variable resistors can be used to adjust the various output voltages.
Module alimentation fantôme régulée symétrique 48V 5V +15/0/-15V
1Réglage sortie 48V
2Switch ON/OFF
3Réglage tension positive sortie -15/0/+15V
4Réglage tension négative sortie -15/0/+15V
5Sortie 5V
6Sortie 48V
7Sortie -15/0/+15V
Product typeRegulated Phantom Power Supply Module
Input voltage220V AC
Output voltages48V DC (adjustable)
5V DC
+15/0/-15V (adjustable)
Intensity (output)48volts ......2ma
+- 13.75volts .....150ma
+ 5 volts ....150ma
Regulators2x LM317
1x LM337T
1x L78
ON/OFF Switch
Input connectorIEC C14
Dimensions148 x 91mm
Fixation holes spacing119.5 x 84mm
Weight440g
InputIEC C14
OutputScrew terminals
Output voltage (V)48.0
Output voltage (V)5.0
Output voltage (V)15.0
Output current (A)0.1
Output current (A)2.0
Input voltage (V)220.0
Power SupplyPhantom power
This regulated phantom power module is ideal for powering a microphone at 48V DC. The module has the particularity of also providing additional...
