Changement de l' alimentation en une demi heure enfantin
Restitution sonore transcendai tout est plus naturel équilibré aucun regret
This filtered power supply module kit has been designed by LHY Audio at Beatechnik's request, and is intended for use with the Bluesound Node X and N130 products. This filtered power supply improves the performance of the Bluesound Node X and Bluesound N130 network players, as using a filtered power supply rather than a switch-mode power supply offers many advantages, not least a great improvement in the sound reproduction quality of your devices.
This power supply module features three C-L/C-L/C-L/C filter stages and is made up of numerous capacitors and inductors. The input is on a DC 5.5/2.1mm connector and accepts DC 5V. The wiring supplied is silver-plated.
Removing or changing the power supply of the Bluesound Node X / N130 invalidates the warranty.
Product type | Filtered power supply module kit |
Supply voltage/current | 5V DC |
Connector | DC 5.5/2.1mm |
Input | Jack DC 5.5/2.1mm |
Output | PCB Connector |
Output voltage (V) | NC |
Output current (A) | NC |
Input voltage (V) | 5.0 |
Power Supply | Power supply filter |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cyril J.
