Stable, mais le radiateur trop fin et petit demande a etre remplace pour un bon fonctionnenent longue duree... au moins 2 fois plus grand avec 5mm d'epaisseur
This +/- regulated linear power supply module has an efficient design, enabling it to offer excellent performance especially for a DIY audio mount. Indeed, this one benefits from a double regulation. If the LM317T and LM337T chips could be sufficient, the two TL431 controllers provide a better thermal and electrical stability but also a lower noise to enjoy a clean signal.
In addition to these regulators, the power supply has quality components, such as its capacitors NOVER (RH13) and WIMA.The module allows to adjust the output voltage according to your needs from +/- 5V to 37V at 1.5A
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 10.0 |
Output voltage (V) | 25.0 |
Output voltage (V) | 37.0 |
Output voltage (V) | 5.0 |
Output voltage (V) | 20.0 |
Output voltage (V) | 30.0 |
Output voltage (V) | 35.0 |
Output voltage (V) | 15.0 |
Output current (A) | 1.5 |
Input voltage (V) | 15.0 |
Input voltage (V) | 25.0 |
Input voltage (V) | 33.0 |
Input voltage (V) | 10.0 |
Input voltage (V) | 20.0 |
Input voltage (V) | 30.0 |
Input voltage (V) | 6.0 |
Power Supply | Regulated Linear Power Supply |
Average votes 4.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Sylvain B.
Christian B.
