By buying this product you get 23 loyalty points
The LinearPi Pro, an evolution of the Linear Pi MKII, is a Ian Canada ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to reference #38D. This regulated linear power supply is able to deliver +/-12V. Its ability to deliver a current of 5A makes it the perfect ally for modules requiring high currents, such as the Raspberry Pi5.
Key points and improvements of the IAN CANADA LinearPi Pro :
LinearPi Pro
Linear Pi
Output current
5A
2.5A
Total filtering capacitance
29080uF
13640uF
Architecture
Parallel power stages
Single power stage
PCB
Four layers double thickness copper high current PCB with two additional shield layers
Two layers double thickness copper high current PCB
Ultra low noise
0.8uV RMS rated
Actual noise could be even lower because of the parallel power output stages and the additional shield layers
0.8uV RMS rated
Heatsink
25 x 50 x 50mm
15 x 50 x 50mm
Schottky rectifiers
High speed, ultra-low drop
High speed
One of the key features of the Linear Pi Pro Dual is its transient load response. Indeed, when the load current varies from 1A to 5A, the noise level remains extremely low and the output voltage drop does not exceed 10mV. With output impedance limited to 2.5mOhm (@1kHz), the linear Pi Pro can be considered one of the best-performing low-noise linear power supplies on the market.
Product type | Linear power supply module |
Output voltage | +/-12V DC |
Output current | 5A |
Rated noise | 0.8µV |
Recommended input voltage | 12V configuration: 15VDC |
Transformer recommendation chart | ||
Voltage configuration | Working current | Transformer P/N or equivalent |
12V | 0-3A | 1182M12 or 1182P12 |
0-2A | 1182L12 or 1182M12 |
Dimensions | 132 x 115mm |
Mouting holes spacing | 115.5 x 108mm |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | -12.0 |
Output voltage (V) | 12.0 |
Output current (A) | 5.0 |
Input voltage (V) | 15.0 |
Power Supply | Linear |
