IAN CANADA LINEARPI PRO SOLO Linear Power Supply Module
The LinearPi Pro, an evolution of the Linear Pi MKII, is an ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to reference #38B. This regulated linear power supply is able to deliver 3 different voltages: 5V(default), 3.3V and 12V. Its ability to deliver a current of 5A makes it the perfect ally for modules requiring high currents, such as the Raspberry Pi5.
Reference : 19914
129,00 €tax incl.
107,50 € tax excl.
Ian Canada LinearPi Pro SoloUltra-Low Noise Linear Power Supply Module 12V / 5V / 3.3V 5A
IAN CANADA LinearPi Pro Solo picture
The LinearPi Pro, an evolution of the Linear Pi MKII, is a Ian Canada ultra-low-noise linear power supply capable of delivering high currents. This is the dual model corresponding to reference #38B. This regulated linear power supply is able to deliver 3 different voltages: 5V(default), 3.3V and 12V. Its ability to deliver a current of 5A makes it the perfect ally for modules requiring high currents, such as the Raspberry Pi5.
Key points and improvements of the IAN CANADA LinearPi Pro :
  • 5A continuous output current
  • 5V, 3.3V and 12V configurations
  • Ultra-low output impedance of 2.5mOhm
  • Very low noise level 0.8uV
  • Parallel output architecture
  • 4-layer PCB with double copper thickness and additional shielding layers
  • Total filtering capacity 29080 uF
  • Large heat sink
  • SMT PCB assembly process
  • Several LinearPi Pros can be grouped into a large power supply system using the integrated isolated master/slave on-off control signal chain
LinearPi Pro
Linear Pi
Output current
5A
2.5A
Total filtering capacitance
29080uF
13640uF
Architecture
Parallel power stages
Single power stage
PCB
Four layers double thickness copper high current PCB with two additional shield layers
Two layers double thickness copper high current PCB
Ultra low noise
0.8uV RMS rated
Actual noise could be even lower because of the parallel power output stages and the additional shield layers
0.8uV RMS rated
Heatsink
25 x 50 x 50mm
15 x 50 x 50mm
Schottky rectifiers
High speed, ultra-low drop
High speed
Ian Canada LinearPi Pro Solo: excellent transient response
One of the key features of the Linear Pi Pro Solo is its transient load response. Indeed, when the load current varies from 1A to 5A, the noise level remains extremely low and the output voltage drop does not exceed 10mV. With output impedance limited to 2.5mOhm (@1kHz), the linear Pi Pro can be considered one of the best-performing low-noise linear power supplies on the market.
IAN CANADA LinearPi Pro Solo transient response curve
Schéma Ian Canada LinearPi Pro Solo
Product typeLinear power supply module
Output voltage12V DC
5V DC
3.3V DC
Output current5A
Rated noise0.8µV
Recommended input voltage3.3V configuration: 5VDC
5V configuration: 9VDC
12V configuration: 15VDC
Transformer recommendation chart
Voltage configurationWorking currentTransformer P/N or equivalent
3.3V0-5A1182Q6
0-2.5A1182N6 or 1182L6
5V0-5A1182Q6
0-2.5A1182N6 or 1182M9
12V0-3A1182M12 or 1182P12
0-2A1182L12 or 1182M12
Dimensions132 x 56mm
Mouting holes spacing114.5 x 49mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)12.0
Output voltage (V)5.0
Output voltage (V)3.3
Output current (A)5.0
Input voltage (V)15.0
Input voltage (V)9.0
Input voltage (V)5.0
Power SupplyLinear
IAN CANADA LINEARPI PRO SOLO Ultra-Low Noise Linear Power Supply Module 12V / 5V / 3.3V 5A
The LinearPi Pro, an evolution of the Linear Pi MKII, is an ultra-low-noise linear power supply capable of delivering high currents. This is the...
