IAN CANADA LINEARPI DUAL Ultra-Low Noise Linear Power Supply Module 2x +/-5V / +/-3.3V 2.5A
The Ian Canada Linear Pi Dual is an ultra low noise power supply module delivering high quality, high current, versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application.
Reference : 14760
135,00 €tax incl.
112,50 € tax excl.
This product has been replaced by the new version, the IAN CANADA LINEARPI MKII DUAL Linear Power Supply Module.
Ian Canada LinearPi Dual
Module Alimentation Linéaire Ultra Faible Bruit 2x +/-5V / +/-3.3V 2.5A
Ian Canada LinearPi Module Alimentation Linéaire Ultra Faible Bruit 5V / 3.3V 2A
The Ian Canada Linear Pi Dual is an ultra low noise power supply module delivering high quality, high current, versatile and scalable. It is one of the best linear power supplies for Raspberry Pi or any other digital audio application. Several LinearPi modules can be combined to create a larger power supply system. This module can also be easily upgraded to a supercapacitor power supply by combining it with the IanCanada UcConditioner.
Points clés :
  • Linear power supply 2x +/-5VDC or +/-3.3VDC 2.5A
  • Ultra low noise level 0.8µV
  • Ultra low output impedance
  • High-speed, high-current, low-noise Schottky rectifiers with optional shunt capacitors
  • Integrated ON/OFF control logic with on-board or external ON/OFF switch
  • Multiple LinearPi's can be grouped together to create a complete power system, using the isolated master/slave control signal chain
  • Quick and easy upgrade to a supercapacitor power supply with the UcConditioner module (sold separately)
  • Continuous AC input mode for the best possible sound quality
  • Optional Kelvin sensor input for better performance
  • Deals with the piezoelectric noise of the MLCC
  • PCB with 2 ounce double layer copper circuitry for ultra low ESR
  • Input 6V AC or 7-9VDC
  • Robust SMT design
Product typeLinear power supply module
Output voltage2x +/-5V DC or +/-3.3V DC
Output current2.5A
Noise0.8µV
Input voltage6V AC
7-9V DC
Dimensions132 x 55.5mm
Mouting holes spacing115.5 x 48.5mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output voltage (V)3.0
Output current (A)2.5
Input voltage (V)9.0
Input voltage (V)7.0
Input voltage (V)6.0
Power SupplyLinear
The Ian Canada Linear Pi Dual is an ultra low noise power supply module delivering high quality, high current, versatile and...
