IAN CANADA UCPURE MKII Ultracapacitor Power Supply Module Class A 5V
The Ian Canada UcPure is a supercapacitor power supply module. It uses a set of supercapacitors with a minimum capacity of 3000F to achieve a very high level of performance. Being a totally passive power supply, the module does not generate any feedback and does not integrate any active component.
Reference : 16349
119,00 €tax incl.
99,17 € tax excl.
This product has been replaced by the new version, the IAN CANADA UCPURE MKIII Power supply module.
Ian Canada UcPure MKII
Ian Canada UcPure Module d'alimentation à supercondensateurs Class A 3.3V / 5V / 15V
The Ian Canada UcPure is a supercapacitor power supply module. It uses a set of supercapacitors with a minimum capacity of 3000F to achieve a very high level of performance. Being a totally passive power supply, the module does not generate any feedback and does not integrate any active component. In pure output mode, only the pre-charged supercapacitor pack is applied to the load. It is also capable of delivering up to 1000A of dynamic current with an internal ESR less than 0.58mΩ (continuous output mode).
All in all, the UcPure module is an excellent low-noise, ultra-high dynamic range power supply, ideal for powering sensitive audio devices such as low jitter clocks, DACs or FIFO buffers.
Points clés :
  • Supercapacitor power supply module.
  • Supercapacitors operate in Class A with a current flowing in only one direction.
  • The output voltage is 5V.
  • Has both a switched and a continuous output.
  • The outputs are completely isolated from the charger, input and other circuits.
  • Includes an ON/OFF switch.
  • Has an isolated ON/OFF control chain that can be implemented in a power supply group.
  • Optical isolators are used for all internal operating logics.
  • Can be powered from 9V to 20VDC. An AC power supply is also possible.
  • The precharge current can be set to 3A (default) or 1.5A to accommodate different power supplies.
  • Built-in protection system to prevent the supercapacitor from depleting and the output voltage from dropping.
  • Dynamic output current: up to 1000A (decided by the supercapacitors).
  • Output ESR: < 0.58mΩ
  • Designed for continuous, uninterrupted operation.
Product typeUltracapacitor power supply module
Input voltage9-20VDC
Output voltage5V
Dynamic output currentUp to 1000A (decided by ultracapacitors)
Output ESR< 0.58mΩ
Dimensions132 x 56mm
InputJack DC 5.5/2.5mm
InputSolder pad
OutputPCB Connector
OutputScrew terminals
Output voltage (V)5.0
Output current (A)1000.0
Input voltage (V)20.0
Input voltage (V)9.0
Power SupplyUltracapacitor power supply
The Ian Canada UcPure is a supercapacitor power supply module. It uses a set of supercapacitors with a minimum capacity of 3000F to achieve a very...
