IAN CANADA UCPURE MKIII Ultracapacitor Power Supply Module Class A 5V
UcPure MkIII is a pure ultracapacitor power supply. It uses the 3000F or above capacity ultracapacitor pack to achieve ultimate power performance. Because this is a purely passive power supply, there will be no feedback and no active components are involved when turned on. In pure output mode, only the pre-charged ultracapacitor pack will be applied to the load.
Reference : 17708
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 16-04-2025.
Ian Canada UcPure
IAN CANADA UCPURE MKIII Module d'Alimentation à Supercondensateurs Class A 5V
UcPure MkIII from Ian Canada is a pure ultracapacitor power supply. It uses 3000F or above capacity ultracapacitor pack to achieve ultimate power performance. Because this is a purely passive power supply, no feedback and no active components are involved when turned on. In pure output mode, only the pre-charged ultracapacitor pack will be applied to the load.
It is also capable of delivering up to 1000A of dynamic current with less than 0.58mΩ internal ESR (continuous output mode, decided by the 3000F ultracapacitor pack).
The UcPure MkIII could be the best low-noise, ultra-dynamic power supply yet. The sound quality of sensitive audio applications such as low jitter clock oscillators, DACs, FIFOs and many other circuits will benefit from this UcPure MkIII power supply.
The UcPure MkIII can be configured for 3.3V, 5V (default) and 15V configurations. It is also equipped with a SYNC charge function to be able to recharge the ultracapacitors during music stops.
Key points :
  • Pure ultracapacitor power supply.
  • Ultracapacitors work in class A mode which current going only in one direction.
  • Output can be configured to 3.3V, 5V (default) and 15V.
  • Has both switched and continuous (great for clock oscillators) outputs.
  • Outputs are 100% isolated from charger, input and other circuit when it is turned on at pure mode.
  • Has built-in on/off control switch (on-board or external).
  • Has an isolated on/off control management chain that can be set up in a group of power supplies.
  • Optical isolators are used for all internal operating logics.
  • Can use 9V to 20V DC input for 3.3V/5V configuration and 18V-20V DC input for 15V configuration. AC 9V-12V input is also possible for 3.3V/5V configuration.
  • Pre-charging current has 3A (default) and 1.5A. Two settings to be suitable for different input power supplies.
  • Built-in protection scheme to prevent ultracapacitor from exhausted and low output voltage.
  • Dynamic output current: up to 1000A (decided by the ultracapacitors).
  • Output ESR: Less than 0.58mΩ (3.3V or 5V configuration, decided by the ultracapacitors).
  • Output noise: Decided only by the ultracapacitors.
  • Heavy duty design for 24/7 operation.
UcPure MkIII new features :
  • Add a powerful SYNC UC charging function. Can re-charge the UCs during music stops. This feature can avoid the output voltage drop or trigger the protection mode even if you listen to music for a very long time. SYNC control signal can be connected to the MUTE signal of a FifoPiQ7. More UcPure MkIII can work together with this signal as a control chain. This signal is isolated from UcPure MkIII so it doesn’t affect the power supply performance at all.
  • Upgrade to higher capacitance, higher voltage and ultra-low ESR smoothing capacitors. Make the UcPure MkIII works better for both AC and DC input and tolerance more to different input power supplies.
  • Upgrade to heavy-duty high-performance 10A fast acting standard 5*20mm glass fuse.
  • Bigger and stronger ON/OFF switch on top side of the PCB.
  • More than one UC groups can be in parallel to improve performance more.
Product typeUltracapacitor power supply module
Input tension9-20VDC
Output tension5V
Dynamic output currentUp to 1000A (value decided by ultracapacitors)
Output ESR< 0.58mΩ
Dimensions132*56mm
InputScrew terminals
InputJack DC 5.5/2.5mm
OutputPCB Connector
OutputScrew terminals
Output voltage (V)5.0
Output current (A)1000.0
Input voltage (V)20.0
Input voltage (V)9.0
Power SupplyUltracapacitor power supply
UcPure MkIII is a pure ultracapacitor power supply. It uses the 3000F or above capacity ultracapacitor pack to achieve ultimate power performance....
