Build quality is good and easy to adjust.
It would be even better if it could deliver higher amps.
all in all a perfect product.
To help you choose the right power supply for your projects, we invite you to visit this page.
LT1963A 5V / +/-5V
This LHY Audio triple linear power supply module offers a very nice design quality, using three LDO voltage regulators LT1963A to provide a clean and stable electrical signal. The module can be AC or DC powered and is capable of delivering 5V and/or +/-5V (adjustable over a range of 1.2V to 20V). It can be used to provide three positive outputs or one positive and one +/- output.
Product type | Linear power supply module |
Input voltage | 6-20VDC 6-15VAC |
Output voltage | 3x5V OR 1x5V + 1x +/-5V Adjustable voltage from 1.2V to 20V |
Output current | 1.5A |
Voltage regulators | 3* LT1963A |
Dimensions (L*P*H) | 100*70*29mm |
Mounting holes spacing | 92*62mm |
Input | Solder pad |
Output | Solder pad |
Output voltage (V) | 5.0 |
Output current (A) | 1.5 |
Input voltage (V) | 6.0 |
Input voltage (V) | 20.0 |
Input voltage (V) | 15.0 |
Power Supply | Regulated Linear Power Supply |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
M A.
