Linear Power Supply board MJE15034G Low noise 4.8V à 24V 2A
This is a very high quality regulated power supply with a very low ripple, high precision semi discrete with a double layer circuit.
4.6 / 5
Reference : 11131
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 23-09-2026.
Regulated linear power supply module
MJE15034G Low Noise 4.8V to 24V 2A
module d'alimentation linéaire régulée 5-24V 2A
Equipped with high level components with diodes Schottky, WIMA film capacitors and NOVER, transistors ONMJE15034, this control stage is ideal for audiophile mounts requiring a stable DC power supply.
It is particularly suitable for design and assembly requiring high stability such as DAC or any digital device requiring low pollution and low ripple. It is also suitable for phono stages, low noise preamplifiers.
The voltage reference is processed by two TL072 exchangeable on DIP support 8 by any compatible OPA.
This regulated power supply has several output modes that can be used by soldering and unsoldering the bridges indicated on the board:
  • L (Low Voltage) : 4.8V to 7V (4.8V with 3 jumpers L, M and H)
  • M (Middle Voltage) : 13V to 18V
  • H (High Voltage) : 24.5V to 30V
A suitable cooling radiator is also available for the controllers.
Recommended AC input voltage9V to 24V
DC Output voltage4.8V to 24V or DC5.5V or 2V with protection circuit
Max output current2A
DEL functionVoltage detection on input
Voltage detection on output
Dimensions100 x 70 x 39mm
Weight90g
Fixation holes spacing92mm / 62mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)20.0
Output voltage (V)24.0
Output voltage (V)10.0
Output voltage (V)15.0
Output voltage (V)5.0
Output current (A)2.0
Input voltage (V)9.0
Input voltage (V)15.0
Input voltage (V)24.0
Input voltage (V)10.0
Input voltage (V)20.0
Power SupplyRegulated Linear Power Supply
7 reviews
super regulator
very nice regulator based on the super regulator schematics
with a better opamp like lm6172 it delivers much better performance,i also use it with 2sc5200 instead og the mje15034g transistor for better power dispersion,truly a top end regulator
This review has been posted for Linear Power Supply board MJE15034G Low noise 4.8V à 24V 2A
There is a washer in the regulator heatsink, that is not capable of taking the heat. Might as well remove it before it starts smoking, it's capable of transporting the heat without being screwed to the heatsink.
Bien s'assurer sur voltage de sortie requise
Delivre 3 rangees de sorties seulement et tout voltage entre chacune des 3 rangees est indisponible, on peut utiliser un second regulateur Lm317 en serie comme solution mais l'amperage est alors limitee @ 1.5A, et aussi porter attention une difference minimale de 1.5v pour un bon fontionnement.
Excellent
Gave my huge improvement of sound quality of DAC and another one in sound quality op raspberry SPIDF HAT, both in combination with a 30W R-core transformer.
István B.
Excellent
