Power Module Linear LT3042 for XMOS
This linear power supply module is based on a LT3042 and a high performance transistor A1859A. It benefits from the PSRR architecture dedicated to the power supply of very noise sensitive devices. It is part of the LTC power supply modules well known for their very low noise rate.
4.0 / 5
Reference : 16747
22,90 €tax incl.
19,08 € tax excl.
To help you choose the right power supply for your projects, we invite you to to consult this page.
Linear Power Supply
Linear Power Supply Module LT3042 5V 1A
This linear power supply module is based on a LT3042 and a high performance transistor A1859A. It benefits from the PSRR architecture dedicated to the power supply of very noise sensitive devices. It is part of the LTC power supply modules well known for their very low noise rate. Its construction integrates a precision voltage reference with a high performance voltage buffer. It can be paralleled to further reduce noise, increase output current and split heat sources to avoid hot spots. It can provide a 5V output voltage while maintaining a minimal noise level. It will be ideal for powering all 3.3V 1A modules. This power supply is stabilized with a Nover 6800µF capacitor.
Dimensions LT3042
Product typeLT3042 Linear power supply module
Transistor1x A1859A
Output current (peak)1A
Output current (continuous)500mA
Output voltage3.3V
Output connectorScrew terminal
RMS Noise0.8µV RMS (10Hz - 100kHz)
Noise2nV/√Hz (@ 10kHz)
PSRR79dB (@ 1MHz)
Input voltage range5V to 20V AC
Capacitor1x Nover 6800µF 35V DC
Bandwidth1MHz
Low dropout voltage350mV
Dimensions48 x 52.5mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)3.3
Output current (A)1.0
Input voltage (V)15.0
Input voltage (V)10.0
Input voltage (V)20.0
Input voltage (V)5.0
Power SupplyLinear
Radiateur d'origine trop faible
Stable, mais le radiateur trop fin et petit demande a etre remplace pour un bon fonctionnenent longue duree... au moins 2 fois plus grand avec 5mm d'epaisseur
This review has been posted for Linear Power Supply Module LT3042 3.3V 1A
This linear power supply module is based on a LT3042 and a high performance transistor A1859A. It benefits from the PSRR architecture dedicated to...
