very nice regulator based on the super regulator schematics
with a better opamp like lm6172 it delivers much better performance,i also use it with 2sc5200 instead og the mje15034g transistor for better power dispersion,truly a top end regulator
MJE15034G Low Noise 4.8V to 24V 2A
This is a very high quality regulated power supply with a very low ripple, high precision semi discrete with a double layer circuit.
Equipped with high level components with diodes Schottky, WIMA film capacitors and NOVER, transistors ONMJE15034, this control stage is ideal for audiophile mounts requiring a stable DC power supply.
It is particularly suitable for design and assembly requiring high stability such as DAC or any digital device requiring low pollution and low ripple. It is also suitable for phono stages, low noise preamplifiers.
The voltage reference is processed by two TL072 exchangeable on DIP support 8 by any compatible OPA.
This regulated power supply has several output modes that can be used by soldering and unsoldering the bridges indicated on the board:
A suitable cooling radiator is also available for the controllers.
Recommended AC input voltage | 9V to 24V |
DC Output voltage | 4.8V to 24V or DC5.5V or 2V with protection circuit |
Max output current | 2A |
DEL function | Voltage detection on input Voltage detection on output |
Dimensions | 100 x 70 x 39mm |
Weight | 90g |
Fixation holes spacing | 92mm / 62mm |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 24.0 |
Output voltage (V) | 10.0 |
Output voltage (V) | 15.0 |
Output voltage (V) | 5.0 |
Output voltage (V) | 20.0 |
Output current (A) | 2.0 |
Input voltage (V) | 24.0 |
Input voltage (V) | 10.0 |
Input voltage (V) | 20.0 |
Input voltage (V) | 9.0 |
Input voltage (V) | 15.0 |
Power Supply | Regulated Linear Power Supply |
Average votes 4.6 / 5 7 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Adam S.
Lukas B.
Sylvain B.
Joris J.
