Power Supply Module A-19 2x3-20V LT1083
This power supply module takes a voltage input of between 5V and 25V AC and outputs a voltage of ±3V to ±20V DC, depending on the setting of the variable resistors. The module is equipped with high-performance LT1083 voltage regulators mounted on heat sinks.
Reference : 4381
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 22-04-2025.
Power supply module A-19 2x3-20V LT1083
Module alimentation 2x3-20V
Product typePower supply module
Input voltage5-25V AC
Output voltage (adjustable)±3V to ±20V DC
Regulators2x LT1083
Capacitors2x 3300µF 35V
2x 470µF 35V
Dimensions107.7 x 56.9 x 54.7mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)20.0
Output voltage (V)19.0
Output voltage (V)7.0
Output voltage (V)4.0
Output voltage (V)10.0
Output voltage (V)5.0
Output voltage (V)13.0
Output voltage (V)16.0
Output voltage (V)17.0
Output voltage (V)18.0
Output voltage (V)15.0
Output voltage (V)3.0
Output voltage (V)8.0
Output voltage (V)9.0
Output voltage (V)11.0
Output voltage (V)12.0
Output voltage (V)14.0
Output voltage (V)6.0
Output current (A)NC
Input voltage (V)17.0
Input voltage (V)10.0
Input voltage (V)19.0
Input voltage (V)12.0
Input voltage (V)5.0
Input voltage (V)21.0
Input voltage (V)14.0
Input voltage (V)7.0
Input voltage (V)23.0
Input voltage (V)16.0
Input voltage (V)9.0
Input voltage (V)25.0
Input voltage (V)18.0
Input voltage (V)11.0
Input voltage (V)20.0
Input voltage (V)13.0
Input voltage (V)6.0
Input voltage (V)22.0
Input voltage (V)15.0
Input voltage (V)8.0
Input voltage (V)24.0
Power SupplyNC
6 reviews
Very good power supply. Adjustment is stable. Almost no heat dissipation with the right transformer.
This review has been posted for Power Supply Module A-19 2x3-20V LT1083
fine power module
the module perfectly meets my expectations, is easy to set up and therefore keeps exactly the value, even under load.
despite the corona problems, I quickly had the power module at home.
perfect!
Great PSU
It works perfect!
This unit replace an old psu with the classic DC regulators LM317 / LM337.
Somebody here at reviews ask if can works as symmetrical + -v power supply. The answer is absolutely YES!
Works for me exactly as i was need. With AC 10V in every side, i have exactly + - 7.5 V OUTPUT!
The only thing you MUST do is to put a jumper from - to + exactly in the middle of the board (at output side), and grounding this point!
Also, no ripple, and imidiatly you can listen your difference from your old power supply!
Thank you Audiophonics for your products!
 (3)
Great well build product for the money
Great well build product for the money. As far as I was able to measure ripple free output.
Good PSU
I checked the PSU at 18V output and results are very good, undetectable ripple and stable voltage.
This power supply module takes a voltage input of between 5V and 25V AC and outputs a voltage of ±3V to ±20V DC, depending on...
