Power Module Linear LT3042 for XMOS
This linear power supply module with two outputs is based on an LT3042 and a pair of high-performance A1930 transistors from Toshiba. It benefits from the PSRR architecture dedicated to the power supply of devices that are very sensitive to noise.
Reference : 12669
33,90 €tax incl.
28,25 € tax excl.
Alimentation Linéaire
Dual Linear Power Supply Module LT3042 5V 1A
Module d'alimentation linéaire double 2x A1930 5V 1A
This linear power supply module with two outputs is based on an LT3042 and a pair of high-performance A1930 transistors from Toshiba. It benefits from the PSRR architecture dedicated to the power supply of devices that are very sensitive to noise. It is one of the LTC power supply modules well known for their very low noise level. Its construction incorporates a precision voltage reference with a high performance voltage buffer. It can therefore be connected in parallel to further reduce noise, increase output current and split heat sources to avoid hot spots. It can provide a 5V output voltage while maintaining a minimum noise level. It will therefore be recommended to do everything to power all 5V 1A modules, like the USB XMOS / SPDIF interfaces. This power supply module is stable thanks to a Nover 6800µF capacitor.
Product typeLinear power supply module LT3042
Transistors2x Toshiba A1930
Output current1A
Output voltage0 - 15V
Outputs number2x outpus on screw terminals
RMS Noise0.8µV RMS (10Hz - 100kHz)
Noise2nV/√Hz (@ 10kHz)
PSRR79dB (@ 1MHz
Supply voltage range5V to 20V
Capacitor1x Nover 6800µF 135V DC
Bandwidth1MHz
Low voltage dropout350mV
Dimensions73.1 x 52.5mm
Input
  • Screw terminals
Output
  • Screw terminals
Output voltage (V)
  • 1.0
  • 10.0
  • 15.0
  • 5.0
Output current (A)
  • 1.0
Input voltage (V)
  • N/A
Power Supply
  • Linear
2 reviews
Utiliser comme "alim propre" en 5V avec le Digione signature et Modifié en 3.3V pour le ESS9038 de Ian Canada.
This review has been posted for Dual Linear Power Supply Module LT3042 5V 1A
Excellent module
Je l'ai utilisé en rentrant en continu (après les diodes).
Alimentation très silencieuse qui fait bien son job.
This linear power supply module with two outputs is based on an LT3042 and a pair of high-performance A1930 transistors from Toshiba. It benefits...
