EMI / RFI Filter TTA1943 LM317 20V 2A
This linear power module has its own EMI / RFI filter with an additional connector for properly connecting a toroidal transformer.
It uses a Toshiba TTA1943 MOSFET driven by a LM317 for high precision in the low and moderate powers.
Effective filtration occurs through a combination of 4700μF capacity electronic capacitors for a maximum voltage of 32V. Each power rail also benefits from a copper shelf for output filtering.
The output voltage is adjustable using a potentiometer mounted directly on the PCB. The power supply is capable of providing up to 20V / 2A (recommended). with occasional peaks up to 4A.
All values are given in millimeters (mm)
Type | Linear regulated power supply |
EMI / RFI Filter | Yes |
adjustable voltage | up to 20V |
Input Voltage | 20V Max |
Connectors | Screw terminals |
Regulator | TTA1943 driven LM317 |
Dimensions | 100 x 100 x 30 mm |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 20.0 |
Output current (A) | 2.0 |
Input voltage (V) | 20.0 |
Power Supply | Regulated Linear Power Supply |
