Regulated Linear Power Supply Module DC LM317 / MJ15025G 3.3V to 24V 5A
This regulated linear power supply module has an efficient design, enabling it to offer excellent performance especially for a DIY audio mount. Its high-quality components, including its LM317 and MJ15025G controllers as well as its NOVER and WIMA capacitors make it an ideal ally for your system's own power supply.
The module allows to adjust the output voltage according to your needs from 3.3V to 24V DC under 5A (depends on the maximum dissipation capability).
TECHNICAL CHARACTERISTICS
- Voltage Regulators: LM317 / Bipolar Transistor MJ15025G
- Capacitors: NOVER 10000µF 35VDC / WIMA MKP10
- Input Voltage: AC 6V AC 24V
- Output voltage: 3.3VDC to 24VDC 5A (max)
- Mounting hole distances: 84 x 72 mm
- Dimensions: 100 x 85 x 47 mm
- Weight: 202g
![Alimentation linéaire régulée 3.3V à 37V](https://www.audiophonics.fr/img/cms/products/12220/alim-lin%C3%A9aire---inpage1.jpg)
