Regulated Linear Power Supply Board LM317 / MJ15025G DC 3.3V to 24V 5A
4.8 / 5
Reference : 12220
29,90 €tax incl.
24,92 € tax excl.
Regulated Linear Power Supply Module DC LM317 / MJ15025G 3.3V to 24V 5A
This regulated linear power supply module has an efficient design, enabling it to offer excellent performance especially for a DIY audio mount. Its high-quality components, including its LM317 and MJ15025G controllers as well as its NOVER and WIMA capacitors make it an ideal ally for your system's own power supply.
The module allows to adjust the output voltage according to your needs from 3.3V to 24V DC under 5A (depends on the maximum dissipation capability).
TECHNICAL CHARACTERISTICS
  • Voltage Regulators: LM317 / Bipolar Transistor MJ15025G
  • Capacitors: NOVER 10000µF 35VDC / WIMA MKP10
  • Input Voltage: AC 6V AC 24V
  • Output voltage: 3.3VDC to 24VDC 5A (max)
  • Mounting hole distances: 84 x 72 mm
  • Dimensions: 100 x 85 x 47 mm
  • Weight: 202g
Alimentation linéaire régulée 3.3V à 37V
InputScrew terminals
OutputScrew terminals
Output voltage (V)10.0
Output voltage (V)24.0
Output voltage (V)20.0
Output voltage (V)15.0
Output current (A)5.0
Input voltage (V)10.0
Input voltage (V)20.0
Input voltage (V)6.0
Input voltage (V)15.0
Input voltage (V)24.0
Power SupplyRegulated Linear Power Supply
4 reviews
excellent board!!
Before this board I tried the Audiophonics 5V LPSU.
I use them to power my Chord 2GO/2YU streamer.
The Audiophonics made a great upgrade over the standard switching psu, but this board made an incredible upgrade over the Audiophonics, it is at another level, clearly superior details and natural sound!!
This review has been posted for Regulated Linear Power Supply Board LM317 / MJ15025G DC 3.3V to 24V 5A
Alim puissante, seul reproche la connexion en entrée n'accepte pas les grosses sections .
Very happy with this board
I use this board together with an 9 Volts R-Core transformer to power up a Raspberry Pi 3 with Hifiberry DAC Pro and a 7 inch official display.
I am able to hear a difference between this power supply an the Meanwell power supply that i have used before.
For me ,now it sounds a little bit more dynamic, while the Meanwell is a little bit "discrete" .
The technical support helped me a lot to find the correct components ,a big "thank you " to you guys from Audiophonics.
 (3)
Fabulous Board--Thanks
This is an excellent power board. Made with great components and just right for DAC projects. Really fast turn around and well shipped. Very responsive to questions. Thanks again!
