Regulated Linear Power Supply Module 3x LT3045 5V DC
This quality regulated linear power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of 5V DC on screw terminal block or 2 pin 3.96mm connector.
Reference : 14978
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 06-05-2025.
Power supply module
Regulated linear power supply 3x LT3045 5V DC
Module d'alimentation linéaire régulée 3x LT3045 5V AC
This quality regulated linear power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of 5V DC on screw terminal block or 2 pin 3.96mm connector. The module embeds an 8VA sealed transformer, as well as 3 LDO LT3045 regulators and two 2200µF filter capacitors, ensuring a clean and stable electrical signal. A heat sink allows to efficiently evacuate the heat released by the LDOs. The assembly is mounted on a transparent acrylic plate.
Product typePower supply module
Power supply typeRegulated linear power supply
LDO Regulators3x LT3045
Input voltage220V AC
Input connectorIEC C8
Output voltage5V DC
OutputScrew terminals
3.96mm 2 pins connector (2 pins to bare wires cable included)
Max output current1.5A
Output power< 6W
Ripple< 1mV
Temperature range-40°C - +85°C
Noise level0.84Vrms (10Hz, 100kHz)
PSRR76dB @ 1MHz
Dimensions105 x 60 x 58mm
Weight355g
Input
  • IEC C8
Output
  • Screw terminals
Output voltage (V)
  • 5.0
Output current (A)
  • 1.5
Input voltage (V)
  • 220.0
Power Supply
  • Regulated Linear Power Supply
This quality regulated linear power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of 5V DC on screw...
