DAYTON AUDIO AUDIOSTROBE AS-1 Stroboscopic Light Woofer Analyzer 1000 Lumens 1-665 FPS
The Dayton Audio Audiostrobe AS-1 has been specially designed for both amateur and professional loudspeaker designers. It emits light flashes synchronized to the sine wave transmitted by a loudspeaker, allowing to clearly visualize the loudspeaker's movement thanks to a visual slow motion effect using the phenomenon of retinal persistence.
Reference : 16829
99,00 €tax incl.
82,50 € tax excl.
Analyseur de Haut-Parleur Lumineux Stroboscopique 1000 Lumens 1-665 FPS
Dayton Audio Audiostrobe AS-1 Analyseur de Haut-Parleur Lumineux Stroboscopique 1000 Lumens 1-665 FPS
The Dayton Audio Audiostrobe AS-1 has been specially designed for both amateur and professional loudspeaker designers. It emits light flashes synchronized to the sine wave transmitted by a loudspeaker, allowing to clearly visualize the loudspeaker's movement thanks to a visual slow motion effect using the phenomenon of retinal persistence. Thus, it becomes easier to detect possible defects of a loudspeaker. The light part of the device is composed of 36 LEDs with a total power of 1000 lumens, allowing it to be used even in well-lit rooms.
The Audiostrobe AS-1 can therefore be used to detect speaker problems such as
  • Non-linearity
  • Cone, surround an dust cap deformations
  • Resonance modes in spider and tinsel leads
  • Lead deformations
  • Spider deformation
  • Phase relationships in multi-speaker systems
  • Tuning frequency and behavior of passive radiators
  • Excursion limits of active and passive drivers
Product typeWoofer analyser
Strobe frequency range60-40000FPM
1-665 FPS
LED number36
Light power1000 lumens
The Dayton Audio Audiostrobe AS-1 has been specially designed for both amateur and professional loudspeaker designers. It emits light flashes...
