DAYTON AUDIO EPIQUE E150HE-44 Speaker Driver Subwoofer DVC MMAG Carbon Fiber 200W 8 Ohm 83dB 30Hz - 4000Hz Ø14cm
Combining excellent performance with a reasonable price, the Epique E150HE-44 Carbon Fiber Diaphragm subwoofer sets a new standard for versatility, distortion and response for small speakers. This dual-coil driver uses a patented MMAG dual-gap motor assembly for unmatched linear excursion capability to create compact systems with deeper bass and lower distortion than ever before.
Reference : 15611
135,00 €tax incl.
112,50 € tax excl.
Shipping date: 27-12-2024.
Dayton Audio Epique E150HE-44
Dayton Audio Epique E150HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 83dB 30Hz-4000Hz Ø14cm
Featuring a carbon fiber cone, dual voice coil, custom surround, FEA optimized motor, cast aluminum frame, large air vents and perfect induction control, the E150HE-44 pushes the limits of a 7" subwoofer.
MMAG Motor
At the core of the E150HE-44 is a patented MMAG (Multiple Magnet Air Gap) dual motor. This unique design uses two top plates spaced between six smaller magnets, creating a longer magnetic gap with more consistent flux than more common dual-gap designs. The combination of the MMAG motor and coil gives the E150HE-44 zero loss of motor force (Bl), even when driven at 10mm excursion, and an overall excursion capability of over 14mm (at 70% Bl). This incredible excursion capability allows for extremely low harmonic and intermodulation distortion to ensure a remarkably clean output even when driven to high output levels. In addition, the motor includes extensive induction control to reduce coil inductance (Le) and improve high frequency response.
Carbon fiber cone
The rigid carbon fiber cone gives the E150HE-44 a unique design while offering a number of performance advantages. With one of the highest strength-to-weight ratios of any material available, carbon fiber minimizes moving mass, allowing for extended low frequencies without sacrificing efficiency. The woven diaphragm has excellent damping properties that control unwanted resonances for a smooth response up to 4000Hz. The optimized profiles of this diaphragm and the dust cap ensure that there is no distortion when exposed to high stresses, so that smooth response and low distortion remain constant, even at high output levels. Finally, the outer edge of the cone has been reinforced to better control cone breakup and help maintain a controlled off-axis dispersion.
Flexible surrounds for high linear excursion
When designing the E150HE-44, Dayton Audio paid particular attention to optimizing the surround to ensure unrestricted excursion without limiting performance. The wide-roller rubber surround was custom-machined for high linear excursion, while paying special attention to the profile to avoid limiting off-axis dispersion. A threaded inner edge adds additional damping to the cone while reducing surround reflections to improve high frequency response. A large diameter progressive spider helps maintain diaphragm linearity when pushed to high excursion. In addition, tinsel wires have been woven into the spider on opposite sides to keep the mass and compliance evenly displaced across the spider.
Large vents for efficient heat dissipation
Excessive heat buildup will increase resistance and result in severe power compression or even failure. To force air through the coil and keep the assembly cooled, the E150HE-44 has an efficient cooling system. Another advantage of the MMAG motor design is the open space between the magnets, which allows consistent airflow directly into the center of the magnetic gap. With this open arrangement, cool air is delivered directly to the coil to remove heat more efficiently. The E150HE-44 also incorporates a vented coil, three large peripheral vents and free airflow under the spider to ensure that every component has airflow through it to keep temperatures to a minimum, even under heavy use for long periods.
Cast aluminum frame
To support its massive motor assembly while providing a solid mounting surface, the E150HE-44 uses a sturdy cast aluminum frame. The minimalist frame design eliminates unwanted reflections and provides ample airflow to the rear of the diaphragm. With plenty of space behind the spider, the E150HE-44 offers a wide excursion capability. Being a non-magnetic material, the aluminum frame has no effect on the magnetic field, allowing the motor to operate effortlessly. In addition, aluminum is an excellent thermal conductor, making it easy to cool.
Dayton Audio Epique E150HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 83dB 30Hz-4000Hz Ø14cm Dayton Audio Epique E150HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 83dB 30Hz-4000Hz Ø14cm Dayton Audio Epique E150HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 83dB 30Hz-4000Hz Ø14cm Dayton Audio Epique E150HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 83dB 30Hz-4000Hz Ø14cm Dayton Audio Epique E150HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 83dB 30Hz-4000Hz Ø14cm
Speaker driver typeSubwoofer
Nominal diameterØ14cm (7")
Power handlingRMS : 200W
Max : 400W
Impedance8Ω
Frequency response30Hz - 4000Hz
Sensitivity83.3dB @ 2.83V/1m
Voice coil diameterØ3.81cm (1.5")
Weight3.7kg
Overall external dimensionsØ152 x 110mm
Thiele-Small Parameters
Resonant frequency (Fs)40Hz
DC Resistance (Re)6.6Ω
Voice coil inductance (Le)1.6mH
Mechanical quality coefficient (Qms)2.94
Electromagnetic quality coefficient (Qes)0.45
Total quality coefficient (Qts)0.39
Compliance equivalent volume (Vas)7.65L (0.27ft.³)
Mechanical compliance of suspension (Cms)0.6mm/N
Force factor (BL)9.8Tm
Diaphragm mass inc. airload (Mms)26.6g
Max linear excursion (Xmax)14.7mm
Surface area of cone (Sd)95cm²
Materials
Cone materialCarbon fiber
SurroundSantoprene®
Voice coil formerAluminum
Frame / Basket materialCast aluminum
Magnet materialCeramic ferrite
Mounting informations
Overall outside diameterØ152.4mm
Cutout diameterØ127mm
Depth104.81mm
Number of mouting holes4
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume3.4L (0.12ft³)
Sealed F379Hz
Vented volume7.1L (0.25ft³)
Vented F341Hz
Speaker Power (W RMS)200.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)140.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)14.0
Lowest frequency (Hz)30
Highest frequency (Hz)4000
Subwoofer epique 5"
Produit envoyé très rapidement et bien emballé.
Toujours un plaisir d'acheter sur audiophonics.
This review has been posted for DAYTON AUDIO EPIQUE E150HE-44 Speaker Driver Subwoofer DVC MMAG Carbon Fiber 200W 8 Ohm 83dB 30Hz - 4000Hz Ø14cm
Combining excellent performance with a reasonable price, the Epique E150HE-44 Carbon Fiber Diaphragm subwoofer sets a new standard for versatility,...
