DAYTON AUDIO EPIQUE E180HE-44 Speaker Driver Subwoofer DVC MMAG Carbon Fiber 200W 8 Ohm 84dB 25Hz - 3000Hz Ø17.8cm
Combining excellent performance with a reasonable price, the Epique E180HE-44 Carbon Fiber Diaphragm subwoofer sets a new standard for versatility, distortion and response for small speakers. This dual-coil driver uses a patented MMAG dual-gap motor assembly for unmatched linear excursion capability to create compact systems with deeper bass and lower distortion than ever before.
Reference : 15610
155,00 €tax incl.
129,17 € tax excl.
Last items in stock !
Shipping date: 29-04-2025.
Dayton Audio Epique E180HE-44
Dayton Audio Epique E180HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 84dB 25Hz-3000Hz Ø17.8cm
Featuring a carbon fiber cone, dual voice coil, custom surround, FEA optimized motor, cast aluminum frame, large air vents and perfect induction control, the E180HE-44 pushes the limits of a 7" subwoofer.
MMAG Motor
At the core of the E180HE-44 is a patented MMAG (Multiple Magnet Air Gap) dual motor. This unique design uses two top plates spaced between six smaller magnets, creating a longer magnetic gap with more consistent flux than more common dual-gap designs. The combination of the MMAG motor and coil gives the E180HE-44 zero loss of motor force (Bl), even when driven at 10mm excursion, and an overall excursion capability of over 14mm (at 70% Bl). This incredible excursion capability allows for extremely low harmonic and intermodulation distortion to ensure a remarkably clean output even when driven to high output levels. In addition, the motor includes extensive induction control to reduce coil inductance (Le) and improve high frequency response.
Carbon fiber cone
The rigid carbon fiber cone gives the E180HE-44 a unique design while offering a number of performance advantages. With one of the highest strength-to-weight ratios of any material available, carbon fiber minimizes moving mass, allowing for extended low frequencies without sacrificing efficiency. The woven diaphragm has excellent damping properties that control unwanted resonances for a smooth response up to 3000Hz. The optimized profiles of this diaphragm and the dust cap ensure that there is no distortion when exposed to high stresses, so that smooth response and low distortion remain constant, even at high output levels. Finally, the outer edge of the cone has been reinforced to better control cone breakup and help maintain a controlled off-axis dispersion.
Flexible surrounds for high linear excursion
When designing the E180HE-44, Dayton Audio paid particular attention to optimizing the surround to ensure unrestricted excursion without limiting performance. The wide-roller rubber surround was custom-machined for high linear excursion, while paying special attention to the profile to avoid limiting off-axis dispersion. A threaded inner edge adds additional damping to the cone while reducing surround reflections to improve high frequency response. A large diameter progressive spider helps maintain diaphragm linearity when pushed to high excursion. In addition, tinsel wires have been woven into the spider on opposite sides to keep the mass and compliance evenly displaced across the spider.
Large vents for efficient heat dissipation
Excessive heat buildup will increase resistance and result in severe power compression or even failure. To force air through the coil and keep the assembly cooled, the E180HE-44 has an efficient cooling system. Another advantage of the MMAG motor design is the open space between the magnets, which allows consistent airflow directly into the center of the magnetic gap. With this open arrangement, cool air is delivered directly to the coil to remove heat more efficiently. The E180HE-44 also incorporates a vented coil, three large peripheral vents and free airflow under the spider to ensure that every component has airflow through it to keep temperatures to a minimum, even under heavy use for long periods.
Cast aluminum frame
To support its massive motor assembly while providing a solid mounting surface, the E180HE-44 uses a sturdy cast aluminum frame. The minimalist frame design eliminates unwanted reflections and provides ample airflow to the rear of the diaphragm. With plenty of space behind the spider, the E180HE-44 offers a wide excursion capability. Being a non-magnetic material, the aluminum frame has no effect on the magnetic field, allowing the motor to operate effortlessly. In addition, aluminum is an excellent thermal conductor, making it easy to cool.
Dayton Audio Epique E180HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 84dB 25Hz-3000Hz Ø17.8cm Dayton Audio Epique E180HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 84dB 25Hz-3000Hz Ø17.8cm Dayton Audio Epique E180HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 84dB 25Hz-3000Hz Ø17.8cm Dayton Audio Epique E180HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 84dB 25Hz-3000Hz Ø17.8cm Dayton Audio Epique E180HE-44 Haut-Parleur Subwoofer DVC MMAG Fibre de Carbone 200W 8 ohm 84dB 25Hz-3000Hz Ø17.8cm
Speaker driver typeSubwoofer
Nominal diameterØ17.8cm (7")
Power handlingRMS : 200W
Max : 400W
Impedance8Ω
Frequency response25Hz - 3000Hz
Sensitivity83.7dB @ 2.83V/1m
Voice coil diameterØ3.81cm (1.5")
Weight3.9kg
Overall external dimensionsØ181.5 x 116mm
Thiele-Small Parameters
Resonant frequency (Fs)35Hz
DC Resistance (Re)6.8Ω
Voice coil inductance (Le)1.5mH
Mechanical quality coefficient (Qms)2.93
Electromagnetic quality coefficient (Qes)0.54
Total quality coefficient (Qts)0.46
Compliance equivalent volume (Vas)16.1L (0.57ft.³)
Mechanical compliance of suspension (Cms)0.61mm/N
Force factor (BL)9.6Tm
Diaphragm mass inc. airload (Mms)32.5g
Max linear excursion (Xmax)14.7mm
Surface area of cone (Sd)136.1cm²
Materials
Cone materialCarbon fiber
SurroundSantoprene®
Voice coil formerAluminum
Frame / Basket materialCast aluminum
Magnet materialCeramic ferrite
Mounting informations
Overall outside diameterØ181mm
Cutout diameterØ154.9mm
Depth111.1mm
Number of mouting holes6
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume8.5L (0.3ft³)
Sealed F362Hz
Vented volume22.6L (0.8ft³)
Vented F330Hz
Speaker Power (W RMS)200.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)178.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)14.0
Lowest frequency (Hz)25
Highest frequency (Hz)3000
4 reviews
Nouvelle vie pour un vieux Yamaha YST-SW50
Possédant un caisson Yamaha subwoofer actif qui a un peu plus de 3 décennies encore fabriqué au Japon à l'époque a récemment perdu la suspension de son haut-parleur. Donc que faire ? Il y a plus de dix ans j'avais acheté un kit subwoofer atohm rafale 38 qui fonctionne toujours à merveille chez audiophonics et très content qu'ils existent toujours... Voilà comment j'ai trouvé ce petit HP ÉPIQUE de Dayton Audio qui remplace depuis peu le HP Yamaha d'origine et je dois dire que le résultat est vraiment terrible ! Je redécouvre mon caisson basse. Très très heureux et merci audiophonics d'être toujours là.
This review has been posted for DAYTON AUDIO EPIQUE E180HE-44 Speaker Driver Subwoofer DVC MMAG Carbon Fiber 200W 8 Ohm 84dB 25Hz - 3000Hz Ø17.8cm
Petit mais costaud (et propre)
Monté dans une enceinte close 2 voies de 10l, qui fait aussi sub. Il monte dans les medium et avec un filtre à 2k + Tweeter, on a un son de basses/sub très propre et pas de "boooom" baveux. mais... nécessite une équalisation forte avec DSP (moi j'ai un module Arylic) qui boost les fréquences en dessous de 80 Hz, + mode Deep Bass, vu que le rendement chute rapidement dans une enceinte close, contrairement à un bass reflex.
Il faut donc pas mal de puissance pour bien ressentir les basses si vous voulez un encombrement minimum. Mais n'achetez pas un ampli de 200 W (la puissance du HP annoncée par Dayton): j'atteins le xMax avec un ampli de 80 W. Le HP peut aussi être monté avec 2 radiateurs passifs de la même gamme Epique.
Impressionnant
Un superbe subwoofer, très bien construit et qualitatif. Monté dans un caisson clos de 8,5l fitlré à 60hz ....le résultat est terrible, rapide et une très belle frappe, aucun trainage. Un excellent choix.
Service Audiophonics parfait !
belle découverte
Je cherchais à faire un petit sub pour compléter un LB dans un volume réduit. Dans 22 litres, soit une caisse de 33cm au cube, ce petit haut parleur remplit bien son office en créant un soubassement convaincant. Alimenté par un ampli transistors de 30 watts et filtré actif à 80Hz en 12 dB/octave, çà fait le job à niveau confortable 80/85dBSPL.
Combining excellent performance with a reasonable price, the Epique E180HE-44 Carbon Fiber Diaphragm subwoofer sets a new standard for versatility,...
