DAYTON AUDIO PRO ODEUM 12LF Subwoofer
Dayton Audio presents its Odeum range of high-end professional loudspeakers. The Pro 12LF is a subwoofer with incredible performance. It is based on a careful, intelligent design, enabling it to be installed in demanding systems requiring high power reproduction with fidelity.
By buying this product you get 20 loyalty points
Reference : 18712
209,00 €tax incl.
174,17 € tax excl.
This product is temporarily unavailable.
DAYTON AUDIO PRO 12LF ODEUM Subwoofer 400W 8 ohm 94.5dB 30hz-1500Hz
Photo of DAYTON AUDIO PRO 12LF ODEUM subwoofer speaker
Dayton Audio presents its Odeum range of high-end professional loudspeakers. The Pro 12LF is a subwoofer with incredible performance. It is based on a careful, intelligent design, enabling it to be installed in demanding systems requiring high power reproduction with fidelity. Here are the highlights of the Dayton Audio Pro 12LF subwoofer speaker:
  • High-quality construction for a robust product
  • Balanced SPL/Xmax ratio provides power and reach
  • Powerful Y35-grade ferrite motor
  • Treated paper cone for optimum strength and durability
  • Progressive-winding spider for better cone control in case of strong excursions
  • 3" voice coil wound from the inside out on a fiberglass support for good power handling
  • Excessive ventilation to reduce power compression
  • Unidirectional linear Xmax over 9 mm for enhanced low-frequency performance
Dayton Audio Pro 12LF: a professional low-frequency loudspeaker
The Dayton Audio Pro 12LF is a 12" professional subwoofer that guarantees superior performance in a PA system. This speaker achieves up to 400W RMS power thanks to a ferrite motor and a 3" voice coil with fiberglass support. It also features extended ventilation for subwoofer power handling and reduced power compression. The treated paper cone with fabric suspension provides a neutral, easy-to-tune sound.
Dayton Audio Pro 12LF: a speaker built to last
The Dayton Audio Pro 12 LF loudspeaker delivers big power in a small form factor. The large motor demands impressive control and enables a low Qt of 0.21, meaning it's ideally suited to small, vented loudspeakers. An impedance of 8 ohms means that a pair can be used in a space as small as 2.3 cubic feet (65L), with a high-output design that supports 800 Watts and extends to bass at 30Hz, achieving sound pressure levels in excess of 94 dB.
Photo of DAYTON AUDIO PRO 12LF ODEUM subwoofer dimensions and measurements
Speaker driver typeSubwoofer
Nominal diameterØ304mm (12")
Handling powerRMS : 400W
Max : 8000W
Impedance8Ω
Frequency response30Hz - 1500Hz
Sensitivity94.5dB @ 2.83V/1m
Voice coil diameterØ76.2mm (3")
Weight9.5kg
Overall external dimensionsØ324*143mm
Magnet weight-
Thiele-Small parameters
Resonant frequency (fS)28Hz
DC resistance (RE)6.7Ω
Voice coil inductance (LE)1.47mH
Mechanical quality factor (QMS)5.19
Electromagnetic quality factor (QES)0.22
Total quality factor (QTS)0.21
Compliance equivalent volume (VAS)147.81L (5.222ft³)
Mechanical compliance of suspension(CMS)0.37mm/N
Force factor (B·l)21.8T·m
Mechanical resistance (RMS)-
Diaphragm mass inc. airload (MMS)88.3g
Max linear excursion (XMAX)9.25mm
Surface area of cone (SD)533cm²
Material
ConeCoated paper
SurroundCloth
Voice coil wireCopper
Voice coil formerFiberglass
FrameAluminum
MagnetFerrite
Mounting informations
External diameterØ304.8mm (12.6")
Cutout diameterØ279.4mm (11.5")
Depth127mm (6")
Fastening circle diameter-
Number of mounting holes8
OPTIMUM CASE SIZE
Sealed volume25.48L (0.9pi³)
Sealed F3110Hz
Vented volume25.48L (0.9pi³)
Vented F3 bass-reflex41Hz
Speaker Power (W RMS)400.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)304.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)94.5
Max Linear Excursion (Xmax) (mm)9.25
Lowest frequency (Hz)30
Highest frequency (Hz)1500
DAYTON AUDIO PRO ODEUM 12LF Subwoofer 400W 8 ohm 94.5dB 30hz-1500Hz
Dayton Audio presents its Odeum range of high-end professional loudspeakers. The Pro 12LF is a subwoofer with incredible performance. It is based...
