DAYTON AUDIO PSS545HE-4 VORTEX Speaker Driver Subwoofer 2000W 4 Ohm 98dB 18Hz - 600Hz Ø53.3cm
If you need a large air displacement for excellent SPL bass response, the Dayton Audio PSS545HE-4 subwoofer is for you, outperforming most high-performance subwoofers in the industry. This massive driver is capable of a linear excursion of 21mm in each direction (@ 70% BL, verified by Klippel) allowing a displacement of 7L. But a large air displacement is not enough. High power handling and high efficiency are also indispensable. Thus, this subwoofer supports RMS power up to 2000W and has a sensitivity of 97.7dB, allowing it to deliver very deep bass.
By buying this product you get 84 loyalty points
Reference : 14748
849,00 €tax incl.
707,50 € tax excl.
This product is temporarily unavailable.
Haut-Parleur Subwoofer 2000W 4 Ohm 98dB 18Hz - 600Hz Ø53.3cm
Dayton Audio PSSS545HE-4 Haut-Parleur Subwoofer 2000W 4 Ohm 98dB 18Hz - 600Hz Ø53.3cm
Over-Excursion Protection
The PSS545HE-4 is designed to reproduce extremely low frequencies at high powers for long periods of time. To prevent breakage and extend the life of the subwoofer, Dayton Audio incorporates an OEP (Over-Excursion Protection) system that audibly alerts you if the speaker's limits are reached. It is therefore designed to accompany you for many years of listening.
Powerful motor
The Dayton Audio PSSS545HE-4 is powered by a high-energy dual ferrite motor. Unlike Neodymium magnets, ferrite magnets are capable of delivering a constant motor force, even in high heat to keep compression to a minimum. The coil is placed in a fiberglass support that can withstand extreme temperatures to accept power up to 2000W RMS without any problem. A large opening on the pole piece, 6 peripheral vents and many others between the salad bowl and the field plate allow a large air flow through the coil to further reduce the compression caused by the increase in resistance due to heat. This allows the PSS545HE-4 to provide a constant low-frequency output, even when pushed at extreme sound pressure levels for long periods of time.
Rugged, durable and built to handle abuse
Dayton Audio first designed this loudspeaker for demanding professional environments. The naturally damped paper cone is optimized and reinforced to withstand the stresses of large linear excursions without deforming. To keep this under control, the PSS545He-4 uses two large-diameter, widely-spaced spiders to ensure perfect linearity. A quadruple suspension allows for high linear excursion even at very high levels. A massive cast aluminum bowl keeps everything in place without restricting airflow. Push-button terminals allow an efficient and secure connection.
Dayton Audio PSSS545HE-4 Haut-Parleur Subwoofer 2000W 4 Ohm 98dB 18Hz - 600Hz Ø53.3cm Dayton Audio PSSS545HE-4 Haut-Parleur Subwoofer 2000W 4 Ohm 98dB 18Hz - 600Hz Ø53.3cm
Speaker driver typeSubwoofer
Nominal diameterØ53.34cm (21")
Power handlingRMS : 2000W
Max : 4000W
Impedance4Ω
Frequency response18Hz - 600Hz
Sensitivity97.7dB @ 2.83V/1m
Voice coil diameterØ127mm (5")
Weight52.6kg
Thiele-Small Parameters
Resonant frequency (Fs)28.8Hz
DC Resistance (Re)3.8Ω
Woofer voice coil inductance (Le)8.2mH
Mechanical quality coefficient (Qms)7.28
Electromagnetic quality coefficient (Qes)0.28
Total quality coefficient (Qts)0.27
Compliance equivalent volume (Vas)7.49 ft.³
Mechanical compliance of suspension (Cms)0.06mm/N
Force factor (BL)35.5Tm
Diaphragm mass inc. airload (Mms)511.2g
Maximum linear excursion (Xmax)21mm
Surface area of cone (Sd)1590cm²
Materials
Cone materialTreated paper
Surrounding materialCloth
Voice coil wireCopper
Voice coil formerFiberglass
Basket / Frame materialCast Aluminium
Magnet materialFerrite
Mounting informations
Overall external diameterØ544.8mm (21.45")
Baffle cutout diameterØ495.3mm (19.5")
Depth258.6mm (10.18")
Bolt circle diameterØ520.7mm (20.5")
Number of mounting holes8
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume1.5ft³
Sealed F377Hz
Vented volume6ft³
Vented F335Hz
Speaker Power (W RMS)2000.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)530.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)98.0
Max Linear Excursion (Xmax) (mm)21.0
Lowest frequency (Hz)18
Highest frequency (Hz)600
If you need a large air displacement for excellent SPL bass response, the Dayton Audio PSS545HE-4 subwoofer is for you, outperforming most...
