DAYTON AUDIO RSS210HF-4 Reference Speaker Driver Subwoofer Aluminium 280W 4 Ohm 86dB 27Hz - 1000Hz Ø20.5cm
Reference : 4942
165,00 €tax incl.
137,50 € tax excl.
This product is temporarily unavailable.
Integrated into the "Reference Series"of DAYTON AUDIO, the bass unit RSS210HF-4takes on board the quality and performance criteria that made the success of esteem of the "RS" line of the American manufacturer.
As with all speakers of the reference series, the main objective of this subwoofer is to maintain extremely low distortion ratesdespite a dizzying descent into the serious infra.
Thus the inter-modulation distortions of 2nd and 3rd orders are kept in respect by the use ofthree distinct electrical shortcuts of the engine.
A spider made of Aramid fiber, with exceptional thermal and mechanical resistance, helps to ensure linear and silent excursionof the mobile crew
Notably, the RSS210HF-4also adopts a devastating look with itscone Aluminum color black anodized , herlarge suspension half rubber rollerhigh quality, and sound chassis owner rigidand perfectly ventilated.
"High Fidelity" (HF) version for home audio applications oriented to the accuracy and quality of bass reproduction, with no special constraints on the volume of the load.
https://www.audiophonics.fr/images2/4942_DAYTON-RSS215HF-4_1.jpg
Features:/ Strong>
  • Largely ventilated motor eliminating compression phenomena that are harmful to the linearity and silence of the excursion
  • Very resistant cone Aluminum Anodized Black
  • Three-way electric motor for minimum distortion
  • Double Layer Coiloffering superior protection to EMI
  • Suitable for installation in load close or bass-reflex
  • High quality building materials for increased durability
Specifications:
dayton audio rs210HF
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume15.57 Litres
Sealed F348 Hz
Vented Volume49.84 Litres
Vented F324 Hz
Speaker Power (W RMS)280.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)205.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)9.0
Lowest frequency (Hz)27
Highest frequency (Hz)1000
Très mécontent
Excellent produit, graves profonds.
Dommage que les stocks ne soient pas correctement tenus, car en cas de non disponibilité, les délais sont très longs.... Il faut compter deux mois.... Inadmissible.
This review has been posted for DAYTON AUDIO RSS210HF-4 Reference Speaker Driver Subwoofer Aluminium 280W 4 Ohm 86dB 27Hz - 1000Hz Ø20.5cm
