DAYTON AUDIO RSS210HO-4 Speaker Driver Subwoofer Aluminium 300W 4 Ohm 86dB 30Hz - 1500Hz Ø20.3cm
The RSS210HO-4 is a subwoofer from Dayton Audio's Reference Series range, and has the same high quality and performance criteria that have made the success of the RS line from the American manufacturer.
Reference : 14415
199,00 €tax incl.
165,83 € tax excl.
This product is temporarily unavailable.
Dayton Audio RSS210HO-4
Dayton Audio RSS210HO-4 Haut-Parleur Subwoofer Aluminium 300W 4 Ohm 86dB 30Hz - 1500Hz Ø20.3cm
As for all the speakers of the Reference Series, the main objective of this subwoofer is to maintain extremely low distortion rates in spite of a vertiginous descent into the subwoofer.
Thus, 2nd and 3rd order intermodulation distortions are maintained by the use of three separate electrical shortcuts inside the motor. An aramid fibre spider, with outstanding thermal and mechanical resistance, helps to ensure a linear and silent excursion of the mobile crew.
The RSS210HO-4 adopts a modern design with its black anodized aluminum cone, its wide half roller suspension made of high quality rubber and its rigid and perfectly ventilated proprietary chassis.
  • Highly ventilated engine eliminates compression phenomena harmful to the linearity and silence of the excursion.
  • Very thick black anodised aluminium cone for maximum rigidity.
  • Three-way electric motor for minimum distortion.
  • Four-layer coil for high power handling.
  • Optimized for small loudspeaker boxes.
  • High quality construction materials for increased durability.
Speaker typeSubwoofer
Nominal diameterØ20.32cm (8")
PowerRMS : 300W
Max : 600W
Impedance4Ω
Frequency response30Hz - 1500Hz
Sensitivity85.7dB @ 2.83V/1m
Voice coil diameterØ50.8mm
Weight5.3kg
Thiele-Small Parameters
Resonant frequency (Fs)29.6Hz
DC Resistance (Re)3.6Ω
Voice coil inductance (Le)0.99mH
Mechanical quality coefficient (Qms)3.33
Electromagnetic quality coefficient (Qes)0.46
Total quality coefficient (Qts)0.40
Compliance equivalent volume (Vas)0.66 ft.³
Mechanical compliance of suspension (Cms)0.29mm/N
Force factor (BL)12Tm
Diaphragm mass inc. airload (Mms)99.3g
Maximum linear excursion (Xmax)11mm
Surface area of cone (Sd)213.8cm²
Displacement volume (Vd)235.2cm³
Materials
ConeAnodized Aluminium
SurroundRubber
Voice coil wire Copper
Voice coil formerAluminium
Basket/FrameAluminium
MagnetFerrite
Mounting informations
Overall external diameterØ213.1mm (8.39")
Cutout diameterØ184.9mm (7.28")
Depth126mm (4.96")
Bolt circle diameter197mm
Number of mounting holes6
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume15.01 Litres
Sealed F351 Hz
Vented Volume47.57 Litres
Vented F327 Hz
Speaker Power (W RMS)300.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)203.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)11.0
Lowest frequency (Hz)30
Highest frequency (Hz)1500
Excellent
Utilisé pour faire un caisson clos d'environ 12l avec un ampli hypex ncore 250. Parfait, puissant, malléable, ça transfigure une installation avec un grave profond rapide et sans trainage....en effet, il existe très très peu d'enceinte du marché capable de vraiment bien reproduire le grave. Avec ce genre d'HP, c'est possible avec un peu d'effort. Excellent rapport qualité prix
This review has been posted for DAYTON AUDIO RSS210HO-4 Speaker Driver Subwoofer Aluminium 300W 4 Ohm 86dB 30Hz - 1500Hz Ø20.3cm
The RSS210HO-4 is a subwoofer from Dayton Audio's  Reference Series  range, and has the same high quality and performance...
