DAYTON AUDIO RSS210HO-8 Reference Speaker Driver Subwoofer Aluminium 300W 8 Ohm 84dB 30Hz - 1500Hz Ø21.3cm
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with the entire Reference Series, these subwoofers feature ultra-low distortion. Second-order, third-order and intermodulation distortion is kept extremely low thanks to 3 integrated circuits in the motor structure.
Reference : 7524
189,00 €tax incl.
157,50 € tax excl.
This product is temporarily unavailable.
Dayton Audio RSS210HO-8
Dayton Audio RSS210HO-8 Haut-Parleur Subwoofer Aluminium 300W 8 Ohm 84dB 30Hz - 1500Hz Ø21.3cm
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with the entire Reference Series, these subwoofers feature ultra-low distortion. Second-order, third-order and intermodulation distortion is kept extremely low thanks to 3 integrated circuits in the motor structure. The spider, made of aramid fibers and featuring an efficient ventilation system, provides uniform excursion. The anodised aluminium cone, rubber suspension and custom bowl give the speaker a unique high-end design.
Speaker driver typeSubwoofer
Nominal diameterØ20.3cm (8")
PowerRMS : 300W
Max : 500W
Impedance8Ω
Frequency response30Hz - 1500Hz
Sensitivity83.5dB @ 2.83V/1m
Voice coil diameterØ50.8mm (2")
Weight5.3kg
Thiele-Small Parameters
Resonant frequency (Fs)29.6Hz
DC Resistance (Re)5.9Ω
Voice coil inductance(Le)1.46mH
Mechanical quality coefficient (Qms)2.78
Electromagnetic quality coefficient (Qes)0.45
Total quality coefficient (Qts)0.39
Compliance equivalent volume (Vas)0.66 ft.³
Mechanical compliance of suspension (Cms)0.29mm/N
Force factor (BL)15.6Tm
Diaphragm mass inc. airload (Mms)99.3g
Maximum linear excursion (Xmax)12mm
Surface area of cone (Sd)213.8cm²
Materials
ConeAluminum
SurroundRubber
Frame / BasketCast Aluminum
MagnetFerrite
Mounting Informations
Overall outside diameterØ213.1mm (8.39")
Baffle cutout diameterØ184.9mm (7.28")
Depth126mm (4.96")
Number of mounting holes6
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume0.28ft³
Sealed F358Hz
Vented volume0.7ft³
Vented F332Hz
Speaker Power (W RMS)300.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)213.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)84.0
Max Linear Excursion (Xmax) (mm)12.0
Lowest frequency (Hz)30
Highest frequency (Hz)1500
Une vraie merveille !
J'ai installé ce HP dans un caisson reflex de chez Jamo (E 4SUB.1) en remplacement de celui d'origine. On peut dire que cette modification a donné vie à ce caisson car l'amélioration est stupéfiante. Les basses sont profondes et puissantes, incomparables avec ce que c'était auparavant et ce avec l'amplificateur intégré d'origine (70W rms).
Je le conseille à tout ceux qui souhaitent réaliser un très bon caisson de salon ( prévoir entre 20 et 30 litres en basse reflex )
This review has been posted for DAYTON AUDIO RSS210HO-8 Reference Speaker Driver Subwoofer Aluminium 300W 8 Ohm 84dB 30Hz - 1500Hz Ø21.3cm
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with...
