DAYTON AUDIO RSS265HF-4 Reference Speaker Driver Subwoofer Aluminium 350W 4 Ohm 88dB 22Hz - 1000Hz Ø25.5cm
Reference : 4943
249,00 €tax incl.
207,50 € tax excl.
This product is temporarily unavailable.
Integrated into the "Reference Series"of DAYTON AUDIO, the bass unit RSS265HF-4takes on board the quality and performance criteria that made the success of esteem of the "RS" line of the American manufacturer.
As with all speakers of the reference series, the main objective of this subwoofer is to maintain extremely low distortion ratesdespite a dizzying descent into the serious infra.
Thus the intermodulation distortions of the 2nd and 3rd orders are kept in respect by the use ofthree distinct electrical shortcuts of the engine.
A spider made of Aramid fiber, with exceptional thermal and mechanical resistance, helps to ensure linear and silent excursionof the mobile crew
Notably, the RSS265HF-4also adopts a devastating look with itscone Aluminum color black anodized , herlarge suspension half rubber rollerhigh quality, and sound chassis owner rigid and perfectly ventilated.
HF version (High Fidelity) intended fore to home audio applications oriented to precision and bass reproduction quality, with no special constraints on load volume.
Features:
  • Largely ventilated motor eliminating compression phenomena that are harmful to the linearity and silence of the excursion
  • Very resistant cone Aluminum Anodized Black
  • Three-way electric motor for minimum distortion
  • Double Layer Coiloffering superior protection to EMI
  • Suitable for installation in load close or bass-reflex
  • High quality building materials for increased durability
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume15.01 Litres
Sealed F351 Hz
Vented Volume47.57 Litres
Vented F327 Hz
Speaker Power (W RMS)350.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)255.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)12.3
Lowest frequency (Hz)22
Highest frequency (Hz)1000
3 reviews
Impeccable
Livraison très rapide, emballage ok, couplé sur caisson clos. Rien à redire pour le moment
This review has been posted for DAYTON AUDIO RSS265HF-4 Reference Speaker Driver Subwoofer Aluminium 350W 4 Ohm 88dB 22Hz - 1000Hz Ø25.5cm
Royal
Audiophonics au top pour les conseil et la livraison rapide, concernant le HP, monté dans un caisson basse-reflex de 90 litres avec 3 évent en L de 80mm de diamètre et 70cm de longueur,et équipé d un Atohm s250-x,ça pousse fort,c est rapide et sec,je vais quand même le testé en version close et je garderais celui qui me convient le mieux.
Utilisé dans un salon de 32 mètre carré..
Le réglage de l Atohm est a 10 heures
 (3)
Excellent
très bon sub.
Finition irréprochable, Aussi lourd qu'un tank !
Les performances sont également au rendez vous.
Les basses sont puissantes, propres et bien tendues.
Idéal pour un caisson clos de petit volume (le mien fait 28 L)
 (4)
