By buying this product you get 25 loyalty points
DAYTON AUDIO RSS265HF-8 Speaker / Subwoofer Top 25.5cm 4Ω
Integrated into the "Reference Series"of DAYTON AUDIO, the bass unit RSS265HF-8takes on board the quality and performance criteria that made the success of esteem of the "RS" line of the American manufacturer.
As with all speakers of the reference series, the main objective of this subwoofer is to maintain extremely low distortion ratesdespite a dizzying descent into the serious infra.
Thus the intermodulation distortions of the 2nd and 3rd orders are kept in respect by the use ofthree distinct electrical shortcuts of the engine.
A spider made of Aramid fiber, with exceptional thermal and mechanical resistance, helps to ensure linear and silent excursionof the mobile crew
Notably, the RSS265HF-8also adopts a devastating look with itscone Aluminum color black anodized , herlarge suspension half rubber rollerhigh quality, and sound chassis owner rigid and perfectly ventilated.
"High Fidelity" (HF) version for home audio applications oriented to the accuracy and quality of bass reproduction, with no special constraints on the volume of the load.
Features:/ Strong>
Specifications:
Download the DataSheet ofDAYTON-RSS265HF-8
Sealed Volume | 24.92 Litres |
Sealed F3 | 43 Hz |
Vented Volume | 79.85 Litres |
Vented F3 | 22 Hz |
Speaker Power (W RMS) | 350.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 255.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 84.0 |
Max Linear Excursion (Xmax) (mm) | 14.3 |
Lowest frequency (Hz) | 25 |
Highest frequency (Hz) | 2000 |
