DAYTON AUDIO RSS265HO-44 Speaker Driver Subwoofer 600W 4+4Ω 90dB 25Hz - 600Hz Ø25.4cm
The Dayton Audio RSS265HQ-44 is a subwoofer with a high output level. It is able to move a large volume of air, supports high power (up to 600W RMS), all with a very low level of distortion. Compact for its performance, it is ideal for applications with limited space.
By buying this product you get 28 loyalty points
Reference : 14880
289,00 €tax incl.
240,83 € tax excl.
Dayton Audio RSS265HO-44
Dayton Audio RSS265HO-44 Haut-Parleur Subwoofer 600W 4+4Ω 90dB 25Hz - 600Hz Ø25.4cm
In order to minimize distortion, three copper paths are integrated into the engine. This design drastically reduces second and third order distortions as well as intermodulation distortions. Another advantage of this model is the reduction of energy storage and inductance, in order to offer excellent musicality, the frequency response remaining linear up to 500Hz.
In addition, the subwoofer's anodized aluminum diaphragm resists deformation, its engine is fully ventilated for reduced power compression, and its rubber suspension ensures excellent durability. The two coils at 4Ω allow for a wide range of wiring options.
Speaker driver typeSubwoofer
Nominal diameterØ254mm (10")
Power handlingRMS : 600W
Max : 1200W
Impedance4+4Ω
Frequency response25Hz - 600Hz
Sensitivity90.5dB @ 2.83V/1m
Voice coil diameterØ65.5mm (2.58")
Thiele-Small Parameters
Resonant frequency (Fs)27.6Hz
DC Resistance (Re)1.6Ω
Voice coil inductance (Le)0.77mH
Mechanical quality factor (Qms)4.42
Electromagnetic quality factor (Qes)0.50
Total quality factor (Qts)0.45
Compliance equivalent volume (Vas)34.83L
Mechanical compliance of suspension (Cms)0.21mm/N
Force factor (BL)9.39Tm
Diaphragm mass inc. airload (Mms)161g
Max linear excursion (Xmax)13.25mm
Surface area of cone (Sd)352.3cm²
Materials
ConeAluminum
SurroundRubber
FrameCast Aluminum
Mounting informations
Total external diameterØ266.7mm (10.5")
Cutout diameterØ234.9mm (9.25")
Depth127mm (5")
Optimum cabinet size (Measured with BassBox 6 Pro High Fidelity)
Sealed volume15.6L (0.55ft.³)
Sealed F346Hz
Vented volume42.5L (1.5ft.³)
Vented F322Hz
Guide : Comprendre les paramètres Thiele & Small
Speaker Power (W RMS)600.0
Speaker TypeSubwoofer
Impedance (Ω)4+4
Loudspeaker diameter (mm)254.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)13.0
Lowest frequency (Hz)25
Highest frequency (Hz)600
The Dayton Audio RSS265HQ-44 is a subwoofer with a high output level. It is able to move a large volume of air, supports high power (up to 600W...
