DAYTON AUDIO RSS315HFA-8 HP Reference Speaker Driver Subwoofer Aluminium 400W 8 Ohm 86dB 25Hz - 1500Hz Ø30.5cm
Built into DAYTON AUDIO's Reference Series, the RSS315HFA-8 Gravity Unit is based on the quality and performance criteria that have made the American manufacturer's "RS" line successful.
By buying this product you get 30 loyalty points
Reference : 12613
309,00 €tax incl.
257,50 € tax excl.
Last items in stock !
Shipping date: 25-04-2025.
Built into DAYTON AUDIO Reference Series, the RSS315HFA-8 Gravity Unit is based on the quality and performance criteria that have made the American manufacturer's "RS" line successful.
As with all the speakers in the reference series, the main objective of this subwoofer is to maintain extremely low distortion rates despite a dizzying descent into the subwoofer.
Thus, the 2nd and 3rd order intermodulation distortions are maintained by the use of three separate electrical shortcuts inside the motor. An Aramid fibre spider, with outstanding thermal and mechanical resistance, contributes to ensuring a linear and silent excursion of the mobile crew.
The RSS315HFA-8 adopts a devastating look with its black anodised aluminium cone, large half-roller suspension made of high quality rubber, and its rigid and perfectly ventilated chassis.
Features:
  • Broadly ventilated motor eliminates compression phenomena harmful to linearity and silence of the excursion
  • Heavy duty black anodized aluminium cone
  • Three-way electric motor for minimal distortion
  • Two-layer coil for reduced rear EMF
  • Optimized for large speakers
  • High-quality construction materials for long service life
  • RMS power 400W / Maximum power 700W
Caractéristiques Dayton Audio RSS315HFA-8
Dimensions RSS315HFA-8 Dayton Audio
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume43.61 Litres
Sealed F340 Hz
Vented Volume131.11 Litres
Vented F320 Hz
Speaker Power (W RMS)400.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)305.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)14.3
Lowest frequency (Hz)25
Highest frequency (Hz)1500
subwoofer dayton
Ottimo altoparlante per subwoofer
prodotto arrivato integro nelle confezione
complimenti a audiophonics , serio e veloce nella spedizione
This review has been posted for DAYTON AUDIO RSS315HFA-8 HP Reference Speaker Driver Subwoofer Aluminium 400W 8 Ohm 86dB 25Hz - 1500Hz Ø30.5cm
Built into DAYTON AUDIO's Reference Series, the RSS315HFA-8 Gravity Unit is based on the quality and performance criteria that have made the...
