DAYTON AUDIO RSS315HO-4 Reference Speaker Driver Subwoofer Aluminium 700W 4 Ohm 90dB 26Hz - 600Hz Ø30.5cm
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with the entire Reference Series, these subwoofers feature ultra-low distortion. Second-order, third-order and intermodulation distortion is kept extremely low thanks to 3 integrated circuits in the motor structure.
Reference : 4940
299,00 €tax incl.
249,17 € tax excl.
This product is temporarily unavailable.
Dayton Audio RSS315HO-4
Dayton Audio RSS315HO-4 Haut-Parleur Subwoofer Aluminium 700W 4Ω 90dB 26Hz - 600Hz Ø30.5cm
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with the entire Reference Series, these subwoofers feature ultra-low distortion. Second-order, third-order and intermodulation distortion is kept extremely low thanks to 3 integrated circuits in the motor structure. The spider, made of aramid fibers and featuring an efficient ventilation system, provides uniform excursion. The anodised aluminium cone, rubber suspension and custom bowl give the speaker a unique high-end design.
Speaker driver typeSubwoofer
Nominal diameterØ30.48cm (12")
PowerRMS : 700W
Max : 1400W
Impedance4Ω
Frequency response26Hz - 600Hz
Sensitivity90.5dB @ 2.83V/1m
Voice coil diameterØ63.5mm (2.5")
Weight11.34kg
Magnet weight4.25kg
Thiele-Small Parameters
Resonant frequency (Fs)26.2Hz
DC Resistance (Re)3.2Ω
Voice coil inductance (Le)1.75mH
Mechanical quality coefficient (Qms)3.63
Electromagnetic quality coefficient (Qes)0.33
Total quality coefficient (Qts)0.31
Compliance equivalent volume (Vas)1.89 ft.³
Mechanical compliance of suspension (Cms)0.15mm/N
Force factor (BL)20Tm
Diaphragm mass inc. airload (Mms)280.9g
Maximum linear excursion (Xmax)12.3mm
Surface area of cone (Sd)514.7cm²
Materials
ConeAluminum
SurroundRubber
Voice coil wireCopper
Voice coil formerAluminum
Basket / FrameCast Aluminum
MagnetFerrite
Mounting Informations
Overall external diameterØ313.94mm (12.36")
Baffle cutout diameterØ281.94mm (11.1")
Depth146.05mm (5.75")
Number of mounting holes8
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume0.33ft³
Sealed F366Hz
Vented volume0.98ft³
Vented F336Hz
Speaker Power (W RMS)700.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)305.0
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)90.0
Max Linear Excursion (Xmax) (mm)12.3
Lowest frequency (Hz)26
Highest frequency (Hz)600
Dayton Audio's Reference Series subwoofers are based on the quality and performance of the excellent RS range, adapted for subwoofers. As with...
