By buying this product you get 36 loyalty points
Integrated into the "Reference Series" range DAYTON AUDIO, the unit of severe RSS390HF-4 takes up the criteria of quality and performance that made the critical success of the line "RS" of the American manufacturer.
As all the speakers in the series reference, the main purpose of this subwoofer is to maintain extremely low distortion rate despite a dizzying descent into the grave below.
So the intermodulation distortion 2nd and 3rd orders are they kept in check by the use of three separate electrical shortcuts internal engine.
A spider aramid fiber, with a thermal and mechanical resistance outside the norm, helps to ensure a silent and linear excursion of the moving equipment.
significant enough, the RSS390HF-4 adopts a more devastating look with its aluminum cone anodised black, its wide suspension half roll in high quality rubber, and rigid chassis owner and perfectly ventilated.
widely ventilated motor eliminating harmful compression phenomena linearity and silence of the tour
Cone highly resistant Anodized Aluminum Black
Triple electrical pathways motor for minimum distortion
dual coil layer providing superior protection against EMI
Suitable for installation in closed box or bass reflex
high quality building materials for longer life
Optimum Cabinet Size (BassBox 6) | |
Volume (sealed) | 81.5 L |
Sealed F3 | 37 Hz |
Volume (vented) | 253.7 L |
Vented F3 | 21 Hz |
Specifications | ||
Impedance | 4ohms | |
DC resistance | 3 ohm | Re |
Inductance of the coil | 0.92 mH @ 1kHz | Le |
Resonant frequency | 19.5 Hz | fs |
mechanical quality factor | 3.02 | Qms |
electrical quality factor | 0.5 | Qes |
total quality factor | 0.43 | Qt |
Moving mass + air load | 306 g | Mms |
Compliance of suspension | 0.22 mm / N | CMS |
Membrane surface | 829.6 cm² | sd |
Maximum air volume displaced | 1.161.4 cm³ | Vd |
Factor strength | 15 Tm | BL |
Volume mass of air equivalent to the compliance of the moving | 212 liters | Vas |
maximum linear excursion | 14.0 mm | Xmax |
diameter VC | 64 mm | |
Sensitivity | 91.2 dB @ 2.83V / 1m | SPL |
supported power | 500 | RMS |
Frequency response | 18-800Hz |
Speaker Power (W RMS) | 500.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 4 |
Loudspeaker diameter (mm) | 380.0 |
Diaphragm type | Aluminium |
Efficiency / Sensitivity (dB) | 91.0 |
Max Linear Excursion (Xmax) (mm) | 14.0 |
Lowest frequency (Hz) | 18 |
Highest frequency (Hz) | 800 |
