Dayton Audio SD270A-88 Subwoofer
The Dayton Audio SD270A-88 is one of the best subwoofers available today in this price range. The brand's DVC range has been designed to offer the best possible value for money.
Reference : 18565
79,00 €tax incl.
65,83 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
Dayton Audio SD270A-88 Speaker Driver Subwoofer DVC 80W 4 Ohm 88dB 26Hz-2000Hz Ø25.4cm
Dayton Audio SD270A-88: Main view
The Dayton Audio SD270A-88 is one of the best subwoofers available today in this price range. The brand's DVC range has been designed to offer the best possible value for money. This loudspeaker features a polyethylene-coated paper diaphragm, wide rubber suspension, large 8 Ohm dual voice coils, vented pole pieces and a dented bowl. The extremely meticulous design of this model makes it an excellent choice for the creation of an economical, high-performance subwoofer.
Dayton Audio SD270A-88: Diagram and measurements
Speaker driver typeSubwoofer
Nominal diameterØ254mm (10")
Power handlingRMS : 80W
Max : 160W
Impedance4Ω
Frequency response26Hz - 2500Hz
Sensitivity87.8dB @ 1W/1m
Voice coil diameterØ38.1mm
Weight2.81kg
Total external dimensionsØ260 x 109mm
Magnet weight-
Thiele-Small parameters
Resonant frequency (fS)26.2Hz
DC Resistance (RE)3.16Ω
Voice coil inductance (LE)1.12mH
Mechanical quality factor (QMS)3.23
Electromagnetic quality factor (QES)0.5
Total quality factor (QTS)0.43
Compliance equivalent volume (VAS)107.6L
Mechanical compliance of suspension (CMS)0.64mm/N
Force factor (B·l)7.8T·m
Mechanical resistance (RMS)-
Diaphragm mass inc. airload (MMS)57.7g
Moving mass (MMD)-
Max linear excursion(XMAX)6mm
Displaced air volume at Xmax (VD)-
Efficiencty (η₀)-
Bandwidth efficiency (EBP)-
Surface area of cone (SD)346.4cm²
Materials
ConeCoated paper
SurrounfRubber
Voice coil wireCopper
Voice coil formerAluminum
FrameSteel
MagnetFerrite
Mounting informations
External diameterØ260mm
Cutout diameterØ227mm
Depth109mm
Bolt circle diameter-
Number of mounting holes5
Taille de caisse optimale
Sealed volume28.32L (1ft³)
Sealed F350Hz
Vented volume49.55L (1.75ft³)
Vented F334Hz
Speaker Power (W RMS)80.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)254.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)26
Highest frequency (Hz)2000
DAYTON AUDIO SD270A-88 Speaker Driver Subwoofer DVC 80W 4 Ohm 88dB 26Hz-2000Hz Ø25.4cm
The Dayton Audio SD270A-88 is one of the best subwoofers available today in this price range. The brand's DVC range has been designed to offer...
