DAYTON AUDIO SD215A-88 Speaker Driver Subwoofer DVC 80W 8+8 Ohm 86dB 31Hz-2500Hz Ø20.3cm
The Dayton Audio DVC subwoofer range has been designed to offer the best possible value for money. They feature a coated paper diaphragm, a large rubber surround and a large dual voice coil. They also allow a large linear excursion and offer excellent sound performance.
Reference : 16316
53,90 €tax incl.
44,92 € tax excl.
This product is temporarily unavailable.
Dayton Audio SD215A-88
Speaker Driver Subwoofer 80W 8+8Ω 86dB Hz - 20kHz Ø8cm 31Hz-2500Hz Ø20.3cm
Dayton Audio SD215A-88 Haut-Parleur Subwoofer 80W 8+8Ω 86dB Hz - 20kHz Ø8cm 31Hz-2500Hz Ø20.3cm
Dayton Audio SD215A-88 Haut-Parleur Subwoofer 80W 8+8Ω 86dB Hz - 20kHz Ø8cm 31Hz-2500Hz Ø20.3cm Dayton Audio SD215A-88 Haut-Parleur Subwoofer 80W 8+8Ω 86dB Hz - 20kHz Ø8cm 31Hz-2500Hz Ø20.3cm
Speaker driver typeSubwoofer
Nominal diameterØ203.2mm (8")
Power handlingRMS : 80W
Max : 160W
Impedance8+8Ω
Frequency repsonse31Hz - 2500Hz
Sensitivity85.9dB @ 1W/1m
Voice coil diameterØ38.5mm
Weight-
Overall dimensionsØ216 x 95mm
Magnet weight-
Thiele-Small Parameters
Resonant frequency (fS)31Hz
DC Resistance (RE)3.2Ω
Voice coil inductance (LE)1.16mH
Mechanical quality factor (QMS)3.10
Electromagnetic quality factor (QES)0.45
Total quality factor (QTS)0.39
Suspension equivalent air volume (VAS)38.2L
Suspension mechanical compliance (CMS)620µm/N
Force factor (B·l)7.7T·m
Mechanical resistance (RMS)2.7N·s/m
Moving mass including airload (MMS)42.4g
Moving mass (MMD)40.1g
Maximum linear excursion (XMAX)±6mm
Displacement volume a Xmax (VD)125.2cm³
Efficiency (η₀)0.25%
Efficiency bandwidth product (EBP)68
Surface of the cone (SD)208.7cm²
MAterials
DiaphragmCoated paper
SurroundRubber
Voice coil wireCopper
Voice coil formerAluminum
FrameSteel
MagnetFerrite
Mounting infortmations
Overall outside diameterØ216mm
Cutout diameterØ180mm
Depth95mm
Bolt circle diameterØ206.4mm
Number of mounting holes5
Optimum cabinet size (Measured with BassBox 6 Pro)
Sealed volume9.34L (0.33ft³)
Sealed F368Hz
Vented volume26.9L (0.95ft³)
Vented F338Hz
Speaker Power (W RMS)80.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)203.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)6.0
Lowest frequency (Hz)31
Highest frequency (Hz)2500
The Dayton Audio DVC subwoofer range has been designed to offer the best possible value for money. They feature a coated paper diaphragm, a large...
