By buying this product you get 28 loyalty points
Model SP10 uses proprietary technology HiVi Symmetric Motor Drive(SMD), which consists in immersing the moving coil in the center of a powerful symmetrical magnetic field .
This symmetrization of the motor allows reducing the inductance of the movable part , and thuscontrol movement more effectively of the membrane.
The support of this crew participates actively in the " evacuation of thermal releases , and ensures the loudspeaker longevity.
The winding employs aluminum wireallowing a superior power holding, with perfectly controlled and linear displacements on one XMAX 15.5mm.
The membrane is made from multilayer pressed paper , guaranteeing a rigidity and an impermeability outside norm.
SSpecifications:
HiViSP10:Dimensions
HiViSP10:Frequency Response
HiViSP10:Impedance Curve
