MONACOR RAPTOR-6 Speaker Driver Subwoofer Compact 100W 4 Ohm 88dB Ø16cm
Reference : 1106
159,00 €tax incl.
132,50 € tax excl.
Monacor Raptor-6 16cm
No more excuses!
With the RAPTOR, the RAPTOR-6, it is possible to ride in a small city car just like in a real sports car, a subwoofer worthy of the name.
Certainly, one or two of these 18 cm subwoofers do not turn the car into a "boom car" but the result is nevertheless breathtaking!
Compact subwoofer, 300 W MAX , 100 W RMS , 4 Ω
With this exceptional bass speaker, not only is the installation of a subwoofer in a very small volume possible, but the 18cm (6.5 ") speaker is rightly called RAPTOR. loudspeaker works very fast, with exceptional level of performance in such small enclosures that it can be mounted around the loudspeaker and the recommended bass reflex opening. With an ideal compromise between the hardness of the suspension and the long travel, perfect pulse behavior is achieved throughout the bass range. It goes without saying that this subwoofer is the first choice of high power subwoofers.
Car & HiFi 6/2003
"What the RAPTOR-6 is capable of developing in terms of serious in the car is simply incredible."
ILMAG 15, 07/2003
"a perfect technique"
Speaker Power (W RMS)100.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)160.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)9.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)800
2 reviews
Il en jette le bougre!
Monté en doublette bass reflex dans un caisson d'une quinzaine de litres et alimenté avec un DLS 2x200w, il encaisse sans broncher en offrant une basse ronde et dynamique. Il ne descend pas à 300 hz mais il pousse fort dans les 45hz et offre un grave détonnant dans cette tranche.
On est pas dans le SQL mais dans le démonstratif compact.
Il ravira les amoureux de basses percutantes en manque de place.
This review has been posted for MONACOR RAPTOR-6 Speaker Driver Subwoofer Compact 100W 4 Ohm 88dB Ø16cm
mini sub...maxi son!
mon enceinte portable "maison" manquait de peps...tir corrigé avec cette enceinte qui a tout d'une grande!
très efficace dans les fréquences sous 100Hz
