"a perfect technique"
Monacor Raptor-6 16cm
No more excuses!
With the RAPTOR, the RAPTOR-6, it is possible to ride in a small city car just like in a real sports car, a subwoofer worthy of the name.
Certainly, one or two of these 18 cm subwoofers do not turn the car into a "boom car" but the result is nevertheless breathtaking!
Compact subwoofer, 300 W MAX , 100 W RMS , 4 Ω
With this exceptional bass speaker, not only is the installation of a subwoofer in a very small volume possible, but the 18cm (6.5 ") speaker is rightly called RAPTOR. loudspeaker works very fast, with exceptional level of performance in such small enclosures that it can be mounted around the loudspeaker and the recommended bass reflex opening. With an ideal compromise between the hardness of the suspension and the long travel, perfect pulse behavior is achieved throughout the bass range. It goes without saying that this subwoofer is the first choice of high power subwoofers.
Car & HiFi 6/2003
"What the RAPTOR-6 is capable of developing in terms of serious in the car is simply incredible."
Speaker Type |
Impedance (Ω) |
Loudspeaker diameter (mm) |
Diaphragm type |
Efficiency / Sensitivity (dB) |
Max Linear Excursion (Xmax) (mm) |
Speaker Power (W RMS) |
Lowest frequency (Hz) |
Highest frequency (Hz) |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Narcisse a.
Didier P.
