This Monacor SPH-200CTC dual-coil woofer is particularly well-suited to the natural reproduction of vocals, delivering incredible bass depth. It also delivers astonishingly accurate sound.
Speaker driver type | Woofer |
Nominal diameter | Ø20.3cm |
Power handling | RMS : 2x60W Max : 2x100W |
Impedance | 2x 8Ω |
Frequency response | 22Hz - 4000Hz |
Sensitvity | 88dB/W/m |
Voice coil diameter | Ø50mm |
Magnet weight | 840g |
Magnet diameter | Ø120mm |
Weight | 2.76kg |
Thiele-Small parameters | |
Resonant frequency (Fs) | 22Hz |
DC resistance (Re) | 2x 6.8Ω / 3.4Ω |
Voice coil inductance (Le) | 2x 1.0mH / 1.0mH |
Mechanical quality coefficient (Qms) | 4.91 |
Electromagnetic quality coefficient (Qes) | 0.23 |
Total quality factor (Qts) | 0.22 |
Equivalent volume (Vas) | 75L |
Mechanical suspension compliance (Cms) | 1.16mm/N |
Moving mass (Mms) | 45g |
Force factor (BL) | 9Tm |
Max linear excursion (Xmax) | ±3.75mm |
Effective cone area (Sd) | 214cm² |
Materials | |
Cone | Carbon fiber |
Basket | Diecast |
Voice coil former | Kapton |
Mounting informations | |
Total external diameter | Ø211mm |
Cutout diameter | Ø181mm |
Depth | 115mm |
Bolt circle diameter | Ø181mm |
Number of mounting holes | 4 |
Speaker Power (W RMS) | 60.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 250.0 |
Diaphragm type | Carbon fiber |
Efficiency / Sensitivity (dB) | 88.0 |
Max Linear Excursion (Xmax) (mm) | 3.7 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 4000 |
