Subwoofer Speaker, 2 x 100 WMAX, 2 x 8 Ω Movable coil, molded aluminum bowl, reinforced carbon fiber membrane, ideal for low space. |
![]() | Specifications Speakers | ||
![]() | Impedance (Z) | ![]() | 2 x 8 Ω |
![]() | Resonance frequency (fs) | ![]() | 22 Hz |
![]() | Maximum bandwidth | ![]() | f3-4000 Hz |
![]() | Freq. cut. (F max.) | ![]() | 3500 Hz |
![]() | Maximum power | ![]() | 2 x 100 WMAX |
![]() | Rated power (P) | ![]() | 2 x 60 WRMS |
![]() | Pressure sound. (1W / 1m) | ![]() | 88 dB |
![]() | Compliance susp. (Cms) | ![]() | 1.16 mm / N |
![]() | Moving mass (Mms) | ![]() | 45 g |
![]() | Mechanical resistance (Rms) | ![]() | 1.1 kg / s |
![]() | Mechanical overvoltage. (Qms) | ![]() | 4.91 |
![]() | Electrical overvoltage (Qes) | ![]() | 0.23 |
![]() | Fact. total surge (Qts) | ![]() | 0.22 |
![]() | Volume equ. (VAS) | ![]() | 75l |
![]() | DC resistance. (Re) | ![]() | 2 x 6.8 Ω / 3.4 Ω |
![]() | Inductance coil. (The) | ![]() | 2 x 1.0 mH / 1.0 mH |
![]() | Coil diameter | ![]() | 50 mm |
![]() | Coil holder | ![]() | Kapton |
![]() | Height winding | ![]() | 15.5 mm |
![]() | Air gap height | ![]() | 8 mm |
![]() | Linear excursion (X MAX) | ![]() | ± 3.75 mm |
![]() | Transmitting surface (Sd) | ![]() | 214 cm2 |
![]() | Flight. air displaced (Vd) | ![]() | 80.3 cm3 |
![]() | Force factor (BxL) | ![]() | 9 Tm |
![]() | Ref. (No) | ![]() | 0.5% |
![]() | Magnet diameter | ![]() | 120 mm |
![]() | Magnet Weight | ![]() | 29.5 oz. |
![]() | Cutting | ![]() | Ø 181 mm |
![]() | Mounting depth | ![]() | 115 mm |
![]() | Dimensions | ![]() | Ø 211 mm |
![]() | Weight | ![]() | 2.8 kg |
![]() | Minimum recommended volume | ![]() | |
![]() | closed | ![]() | - |
![]() | bass reflex | ![]() | 20 l |
Speaker Power (W RMS) | 60.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 250.0 |
Diaphragm type | Carbon fiber |
Efficiency / Sensitivity (dB) | 88.0 |
Max Linear Excursion (Xmax) (mm) | 3.7 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 4000 |
