This Monacor SPH-250CTC dual-coil subwoofer reproduces deep bass for total sound immersion.
Speaker driver type | Subwoofer |
Nominal diameter | Ø25.4cm |
Power handling | RMS : 2x100W Max : 2x150W |
Impedance | 2x 8Ω |
Frequency response | 20Hz - 3500Hz |
Sensitivity | 91dB/W/m |
Voice coil diameters | Ø50mm |
Magnet weight | 1.2kg |
Magnet diameter | Ø145mm |
Weight | 3.8kg |
Thiele-Small parameters | |
Resonant frequency (Fs) | 20Hz |
DC resistance (Re) | 2x 6.8Ω / 3.4Ω |
Voice coil inductance (Le) | 2x 1.0mH / 1.0mH |
Mechanical quality coefficient (Qms) | 5.12 |
Electromagnetic quality coefficient (Qes) | 0.26 |
Total quality coefficient (Qts) | 0.25 |
Equivalent volume (Vas) | 220L |
Mechanical suspension compliance (Cms) | 0.98mm/N |
Moving mass (Mms) | 70g |
Force factor (BL) | 9.6Tm |
Max linear excursion (Xmax) | ±4.5mm |
Surface area of cone (Sd) | 343cm² |
Materials | |
Cone | Carbon fibre |
Frame | Diecast aluminum |
Voice coil former | Kapton |
Mounting informations | |
Total outer dimensions | Ø258mm |
Cutout diameter | Ø232mm |
Depth | 123mm |
Bolt circle diameter | Ø243mm |
Number of mounting holes | 4 |
Speaker Power (W RMS) | 100.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 250.0 |
Diaphragm type | Carbon fiber |
Efficiency / Sensitivity (dB) | 91.0 |
Max Linear Excursion (Xmax) (mm) | 4.5 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 3500 |
