Subwoofer Hi-Fi, 2 x 150 WMAX, 2 x 8 Ω Salad bowl in cast aluminum, double coil, carbon fiber reinforced membrane. For high-quality Hi-Fi subwoofers in medium bass-reflex speakers and in 3-way systems. |
![]() | Specifications Speakers | ||
![]() | Impedance (Z) | ![]() | 2 x 8 Ω |
![]() | Resonance frequency (fs) | ![]() | 20 Hz |
![]() | Maximum bandwidth | ![]() | f3-3500 Hz |
![]() | Freq. cut. (F max.) | ![]() | 2000 Hz |
![]() | Maximum power | ![]() | 2 x 150 WMAX |
![]() | Rated power (P) | ![]() | 2 x 100 WRMS |
![]() | Pressure sound. (1W / 1m) | ![]() | 91 dB |
![]() | Compliance susp. (Cms) | ![]() | 0.98 mm / N |
![]() | Moving mass (Mms) | ![]() | 70 g |
![]() | Mechanical resistance (Rms) | ![]() | 1.7 kg / s |
![]() | Mechanical overvoltage. (Qms) | ![]() | 5.12 |
![]() | Electrical overvoltage (Qes) | ![]() | 0.26 |
![]() | Fact. total surge (Qts) | ![]() | 0.25 |
![]() | Volume equ. (VAS) | ![]() | 220l |
![]() | DC resistance. (Re) | ![]() | 2 x 6.8 Ω / 3.4 Ω |
![]() | Inductance coil. (The) | ![]() | 2 x 1.0 mH / 1.0 mH |
![]() | Coil diameter | ![]() | 50 mm |
![]() | Coil holder | ![]() | Kapton |
![]() | Height winding | ![]() | 17 mm |
![]() | Air gap height | ![]() | 8 mm |
![]() | Linear excursion (X MAX) | ![]() | ± 4.5 mm |
![]() | Transmitting surface (Sd) | ![]() | 343 cm2 |
![]() | Flight. air displaced (Vd) | ![]() | 155.7 cm3 |
![]() | Force factor (BxL) | ![]() | 9.6 Tm |
![]() | Ref. (No) | ![]() | 0.8% |
![]() | Magnet diameter | ![]() | 145 mm |
![]() | Magnet Weight | ![]() | 42.7 oz. |
![]() | Cutting | ![]() | Ø 229 mm |
![]() | Mounting depth | ![]() | 120 mm |
![]() | Dimensions | ![]() | Ø 256 mm |
![]() | Weight | ![]() | 3.8 kg |
![]() | Minimum recommended volume | ![]() | |
![]() | closed | ![]() | 35 l |
![]() | bass reflex | ![]() | 60 l |
Speaker Power (W RMS) | 100.0 |
Speaker Type | Subwoofer |
Impedance (Ω) | 8 |
Loudspeaker diameter (mm) | 250.0 |
Diaphragm type | Carbon fiber |
Efficiency / Sensitivity (dB) | 91.0 |
Max Linear Excursion (Xmax) (mm) | 4.5 |
Lowest frequency (Hz) | N/A |
Highest frequency (Hz) | 3500 |
