TANG BAND W3-1876S Speaker Driver Subwoofer 15W 4 Ohm 76dB 55Hz-2kHz Ø7.6cm
The Tang Band W3-1876S is a small subwoofer with a diameter of only 7.6cm, ideal for integration into compact speakers. In spite of its compactness, the W3-1876S provides a solid reproduction of low frequencies.
Reference : 15951
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 08-05-2025.
Tang Band W3-1876S
Tang Band W3-1876S Haut-Parleur Subwoofer 15W 4 Ohm 76dB 55Hz-2kHz Ø7.6cm
The Tang Band W3-1876S is a small subwoofer with a diameter of only 7.6cm, ideal for integration into compact speakers. In spite of its compactness, the W3-1876S provides a solid reproduction of low frequencies. It uses a neodymium magnet motor, a santoprene suspension and a polypropylene diaphragm, capable of a large travel of ±5mm.
Speaker driver typeSubwoofer
Nominal diameterØ76mm (3")
Power handlingRMS : 15W
Max : 30W
Impedance4Ω
Frequency response55Hz - 2000Hz
Sensitivity76dB
Voice coil diameterØ20.4mm
Weight-
Overall external dimensions93.1 x 65.8mm
Magnet weight-
Resonant frequency (fS)55Hz
DC Resistance (RE)3.6Ω
Electrical quality factor (QES)0.50
Mechanical quality factor (QMS)3.17
Total quality factor (QTS)0.43
Suspension equivalent air volume (VAS)0.88L
Maximum impedance (Zmax)75Ω
Voice coil inductance (LE)0.19mH
Force factor (B·l)5.28T·m
Suspension mechanical resistance (RMS)1.1N·s/m
Suspension mechanical compliance (CMS)738µm/N
Moving mass (MMD)9.9g
Moving mass including airload (MMS)9.98g
Surface of the diaphragm (SD)27cm²
Effective diaphragm diameterØ5.9cm
Maximum linear excursion (Xmax)±5mm
Displacement volume at Xmax (VD)13.5cm³
Efficiency (η₀)0.03%
Efficiency bandwidth product (EBP)110
Materials
Diaphragm materialPolypropylene
Surround materialSantoprene
Magnet materialNeodymium
Mounting informations
Overall external diameterØ93.1mm
Cutout diameterØ74.5mm
Total depth65.8mm
Mounting bolt diameterØ84mm
Number of mounting holes6
Informations de montage
Diamètre externe totalØ93.1mm
Diamètre d'encastrementØ74.5mm
Profondeur totale65.8mm
Diamètre du cercle de montageØ84mm
Nombre de trous de montage6
Speaker Power (W RMS)
  • 15.0
Speaker Type
  • Subwoofer
Impedance (Ω)
  • 4
Loudspeaker diameter (mm)
  • 76.0
Diaphragm type
  • Polypropylene
Efficiency / Sensitivity (dB)
  • 76.0
Max Linear Excursion (Xmax) (mm)
  • 5.0
Lowest frequency (Hz)
  • 55
Highest frequency (Hz)
  • 2000
The Tang Band W3-1876S is a small subwoofer with a diameter of only 7.6cm, ideal for integration into compact speakers. In spite of its...
