TANG BAND W6-1139SIF Subwoofer
The Tang Band W6-1139SIF subwoofer delivers immersive bass reproduction thanks to its diameter of no less than 16.5mm. It has a power handling capacity of 50Wrms.
Reference : 19194
115,00 €tax incl.
95,83 € tax excl.
Shipping date: 24-04-2025.
TANG BAND W6-1139SIF Speaker Driver Subwoofer 50W 4 ohm 83dB 35-800Hz Ø16.5cm
Photo of Tang Band W6-1139SIF
The Tang Band W6-1139SIF subwoofer delivers immersive bass reproduction thanks to its diameter of no less than 16.5mm. It has a power handling capacity of 50Wrms. Its paper diaphragm and rubber suspension provide excellent performance.
TANG BAND W6-1139SIF dimensions
Product typeSpeaker
Speaker typeSubwoofer
Diaphragm materialPaper
Surround materialRubber
Structure materialSteel
Magnetic systemFerrite
Nominal impedance4 ohm
DCR impedance3.6 ohm
Sensitivity83dB (1W/1m)
Frequency response35-800Hz
Free air resonance35Hz
Voice coil diameter38.5mm
Air gap height6mm
Rated power RMS50Wrms
Max. power100W
Foce factor (BL)8.47TM
Magnet weight826g
Moving mass39.91g
Suspension compliance598.98uMN
Effective piston area0.0140m²
Levc0.47mH
Zo39 ohm
X-Max11.5mm
Vas11.78L
Qts0.40
QMS2.65
Qes0.47
External diameterØ176.5mm
Cutout diameter141.5
Depth110mm
Mounting bolt diameter166mm
Mounting holes4
Package1x TANG BAND W6-1139SIF Subwoofer
Speaker Power (W RMS)50.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)165.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)83.0
Max Linear Excursion (Xmax) (mm)11.5
Lowest frequency (Hz)35
Highest frequency (Hz)800
The Tang Band W6-1139SIF subwoofer delivers immersive bass reproduction thanks to its diameter of no less than 16.5mm. It has a power handling...
