TANG BAND W4-1720 Speaker Driver Subwoofer 30W 4Ω 86dB Ø12.55cm
The Tang Band W4-1720 subwoofer delivers immersive bass reproduction thanks to its diameter of no less than 12.55mm. It has a power handling capacity of 30Wrms. Its paper diaphragm and rubber suspension provide excellent performance.
Reference : 19286
64,90 €tax incl.
54,08 € tax excl.
TANG BAND W4-1720 : Front view
TANG BAND W4-1720 : Dimensions and SPL versus Frequency
Product typeSpeaker
Speaker typeSubwoofer
Diaphragm materialPaper
Surround materialRubber
Magnetic systemFerrite
Nominal impedance
DCR impedance3.8Ω
Sensitivity86dB
Frequency response60Hz - 8kHz
Free air resonance60Hz
Voice coil diameter32mm
Air gap height17mm
Rated power RMS30W
Max. power60W
Force factor (BL)3.82TM
Moving mass5 g
Suspension compliance1284 uMN¯¹
Effective piston area0.0057m²
Levc0.037mH
Zo22 Ω
Maximum linear peak (X-Max)5mm
Compliance volume (Vas)5.92L
Total quality factor (Qts)0.42
Mechanical quality factor (QMS)2.33
Electrical quality factor (Qes)0.51
External diameterØ125.5mm
Cutout diameter95.5mm
Depth92mm
Mounting bolt diameterØ115mm
Mounting holes4
Package1x TANG BAND W4-1720
Speaker Power (W RMS)30
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)125.5
Diaphragm typePaper
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)5.0
Lowest frequency (Hz)60
Highest frequency (Hz)8000
The Tang Band W4-1720 subwoofer delivers immersive bass reproduction thanks to its diameter of no less than 12.55mm. It has a power handling...
