Convertit un port USB en sortie Audio, ce qui peut etre utile. Logiciel efficace et intuitif. Indispensable !
Speaker Driver Tester
The new version of the DATS tester incorporates an update that improves stability and overall reliability and eliminates start-up time. In addition, it includes a new interface with signal generator, possibility to create data libraries, etc.
The DATS V2 allows you to measure all the parameters related to a loudspeaker with speed, efficiency and simplicity. Plug the USB interface into one of the ports of your PC computer, install the provided measurement software, and you are at the head of a real acoustic testing and modelling laboratory that has little to envy to professional infrastructures, accessibility in addition... For example, it only takes a few seconds for DATS to draw the electrical impedance curve of a transducer developed from 30,000 measurement readings, and barely more to establish a record of the characteristics of the same loudspeaker in the open air. It can even go so far as to inform you about the 1kHz inductance of your speaker filter, or even represent the variations in independence of a multi-channel system.
Its accuracy makes it an essential tool for those who wish to virtualize and evaluate the most complex acoustic configurations before they are implemented. The only limit then becomes your imagination!
Features :
Evolution compared to V1 :
Computer requirements :
Note: On Windows 10, in case of an error during the autocalibration sweep, go to the Windows 10 privacy settings and allow applications to use the microphone.
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Eric C.
gilles F.
Yan V.
