DAYTON AUDIO IMM-6S Measurement Microphone for Smartphones and Tablets
The Dayton Audio iMM-6S is a professional quality measurement and recording microphone designed to work with iDevices (iPad, iPhone, iPod) as well as Android and Microsoft devices with a 3.5mm TRRS jack. Its rugged construction and compact size make it the ideal companion for audio professionals who need to work on location to perform acoustic analysis, monitor audio levels or record.
Reference : 15657
24,90 €tax incl.
20,75 € tax excl.
Dayton Audio iMM-6S
Dayton Audio iMM-6S Microphone de mesure pour smartphones et tablettes
The Dayton Audio iMM-6S is a professional quality measurement and recording microphone designed to work with iDevices (iPad, iPhone, iPod) as well as Android and Microsoft devices with a 3.5mm TRRS jack. Its rugged construction and compact size make it the ideal companion for audio professionals who need to work on location to perform acoustic analysis, monitor audio levels or record. Each iMM-6S is individually hand-calibrated using a standard laboratory measurement microphone, for consistent measurements that match the level of accuracy previously offered only by much more expensive stand-alone microphones.
A unique serial calibration file is available for the iMM-6S. This can be downloaded directly from the Dayton Audio website by entering the microphone model and serial number. This file can then be used in many iOS and Android applications.
Product typeMeasurement microphone
ConnectorGold plated male TRRS Jack 3.5mm
Capsule typePrecision 6mm electret condenser
Polar responseOmnidirectional
Frequency response18Hz - 20kHz ±0.5dB (calibrated)
Impedance200Ω
Sensitivity @ 1kHz, 1kΩ10mV/Pa (-40dBV, re. 0dB = 1V/Pa)
SPL Max. @ THD 1%, 1000Hz127dB
SNR70dB (A-Weighted, varies depending on host devices)
Weight7.6g
Microphone de Mesure pour Smartphones
Microphone de qualité robuste et livré dans une boite métallique.
This review has been posted for DAYTON AUDIO IMM-6S Measurement Microphone for Smartphones and Tablets
The Dayton Audio iMM-6S is a professional quality measurement and recording microphone designed to work with iDevices (iPad, iPhone, iPod) as well...
