MINIDSP UMA-16 Microphone Module MEMS USB 16 Channels
The MiniDSP UMA-16 is a USB microphone Plug & Play high performance 16 channels. With its embedded module SHARC + XMOS, the UMA-16 is an ideal solution for the development of beamforming algorithms (spatial filtering) or the DIY creation of an acoustic camera.
By buying this product you get 36 loyalty points
Reference : 14180
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 16-04-2025.
MiniDSP UMA-16
MiniDSP UMA-16 Module Microphone MEMS USB 16 Canaux
The MiniDSP UMA-16 is a USB microphone Plug & Play high performance 16 channels. With its embedded module SHARC + XMOS, the UMA-16 is an ideal solution for the development of beamforming algorithms (spatial filtering) or the DIY creation of an acoustic camera. Its architecture consists of two key elements:
  • The module integrates 16 MEMS Knowles SPH1668LM4H on a uniform grid (Uniform Rectangular Array). A central hole allows you to install an optional USB camera (not included) for acoustic camera design.
  • At the heart of the UMA-16's operation is a nanoSharc kit consisting of a SHARC ADSP21489 400MHz and a 500MHz multi-core processor offering high processing power for SNR PDM to PCM conversion of low latency USB audio.
Product typeMicrophone module
Microphones16x MEMS Knowles SPH1668LM4H
Acoustic pressure: 120dBSPL
SNR : 65dB
RF Shielding
DSPAnalog Devices SHARC ADSP21489 @ 400MHz, 32bit, floating point
USB Interface / CPUXMOS XCore200 @ 500MHz, up to 192kHz
USB Audio transmission typeAsynchronous
USB inputMini USB-B
Supported ADC/DAC sampling rates24bit
14.7k / 11.025k / 12k / 16k / 22.05k / 44.1k / 48k
USB CompatibilityWindows with ASIO driver
Mac OS X without driver
Power supply12V DC
Dimensions132 x 195 x 25mm
Package1x MiniDSP UMA-16
1x USB / Mini USB Cable 1.5m
1x 12V Power Supply
The MiniDSP UMA-16 is a USB microphone Plug & Play high performance 16 channels. With its embedded module SHARC + XMOS, the UMA-16 is an ideal...
